Unable to mount emmc by "ums 0 mmc 0"
I’m not able to mount the emmc by “ums 0 mmc 0”. Nothing gets mounted on media folders
I have removed JP2 and JP3, and tried “usb start”
The target is running an image built from yocto (kirkstone) upstream 6.6.0.
Environment:
Ubuntu 22.04
apalis imx6
ixora v1.2A
Commercial temperature grade DDR3 timings.
Trying to boot from MMC1
U-Boot 2022.07-6.6.0-devel+git.e092e3250270 (Jul 11 2022 - 13:42:58 +0000)
CPU: Freescale i.MX6Q rev1.6 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 38C
Reset cause: POR
DRAM: 1 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
Core: 112 devices, 18 uclasses, devicetree: separate
MMC: FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 0
Loading Environment from MMC… OK
In: serial@2020000
Out: serial@2020000
Err: serial@2020000
Model: Toradex 0027 Apalis iMX6Q 1GB V1.1B
Serial#: 10685315
Net: eth0: ethernet@2188000
Apalis iMX6 #
Apalis iMX6 # ums 0 mmc 0
UMS: LUN 0, dev mmc 0, hwpart 0, sector 0x0, count 0x748000
USB EHCI 1.00
