I am running the Toradex Linux consol image 2.7 on my Colibri VF61 and I cannot seem to launch an application on the Cortex M4 core. I am confused, because I know I was able to do this several weeks ago. I thought maybe my changes to the device tree file might have caused a problem, so I went back to the Toradex console Linux image and Toradex device tree. Here is what I have done:
I re-flashed the Linux image from Uboot with the commands run setupdate
and run setup
. Then I created a file in /etc/modules_load.d named vf610_cm4_rproc.conf containing the single line vf610_cm4_rproc
. I then put my elf file into the /lib/firmware folder and renamed my elf file to freertos-rpmsg.elf and rebooted the VF61.
Unfortunately my program fails to run on the M4 core. This is the same program that I did run on the M4 core several weeks ago, so I must be doing something wrong now. I don’t remember all the steps I went through to get it to run the first time.
Now I am getting the following messages on the Linux console during boot time:
[ 4.905958] vf610_m4_rproc 3f000000.cortexm4core: can't request region for resource [mem 0x3f000000-0x3f07ffff]
[ 4.933215] vf610_m4_rproc 3f000000.cortexm4core: devm_ioremap_resource failed for resource 0
[ 4.959281] vf610_m4_rproc: probe of 3f000000.cortexm4core failed with error -16
I’m sure this is not good, but I am at a loss as to why I can’t get this to work. Please tell me what I am doing wrong.
