Unable to import library MSVCR90d.dll ! Program will exit
Converted a project which previously ran on CE 5.0 and CE 6.0 into a WINCE7 Toradex SDK project. Get the title message when deploying this project.
NOTE: I have set this for both /MTd and /MDd, same results.
There is a issue for interactivity.dll, and the user is told to check if the dll exists in /FlashDisk/System.
There is no /FlashDisk/System on my Apalis SoM.
You can create that folder if it doesn’t exist, and putting the DLL there should solve the issue. Visual Studio doesn’t deploy it by default, it seems.
