Unable to import library MSVCR110.dll ! Program will exit
I am using Visual Studio 2012 with Colibri T30 SDK Windows Compact 2013.
I had created a Projekt and if I test my Programm I get following error:
Unable to import library MSVCR110.dll ! Program will exit.
What can I do to resolve the problem?
Copy the dll into the folder doesn’t work.
Thank you.
Best Regards.
If you right click to you project and select properties. Under C/C++ → Code Generation change RunTime library from /MD to /MT it will work.
Thank you very much.
It works.
