Unable to flash colibri iMX6
I flashed Colibri-iMX6_LXDE-Image_2.8.6 using easyinstaller. Then using the command “ums 0 mmc 0” flash boot to Qt device in emmc.
When you I turn on the device it does not boot.
I tried to enter:
1. env default -a
2. saveenv
But there are no changes, it doesn’t boot.
Here is Listing
U-Boot 2016.11-2.8.6+g83a53c1c0c (Apr 01 2019 - 09:53:19 +0000)
CPU:   Freescale i.MX6SOLO rev1.4 at 792 MHz
Reset cause: POR
I2C:   ready
DRAM:  256 MiB
PMIC:  device id: 0x10, revision id: 0x21, programmed
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In:    serial
Out:   serial
Err:   serial
Model: Toradex Colibri iMX6 Solo 256MB V1.1A, Serial# 10548006
Net:   using PHY at 0
FEC [PRIME]
Hit any key to stop autoboot:  1  0
Booting from internal eMMC chip...
reading imx6dl-colibri-eval-v3.dtb
50913 bytes read in 21 ms (2.3 MiB/s)
reading zImage
** Unable to read file zImage **
emmcboot failed
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Scanning mmc 0:1...
starting USB...
USB0:   Port not available.
USB1:   USB EHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
       scanning usb for ethernet devices... 0 Ethernet Device(s) found
USB device 0: unknown device
FEC Waiting for PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY FEC
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
Hi @Daria_KI and Welcome to the Toradex Community!
Then using the command “ums 0 mmc 0” flash boot to Qt device in emmc. When you I turn on the device it does not boot.
What exactly are you trying to do?
If you want to boot boot2qt image, then you should install boot2qt using Toradex Easy Installer.
When I flashed Colibri-iMX6_LXDE-Image_2.8.6 I used Easy Installer.
But when I turn on the device it does not boot.
We have Qt for device creation (Linux).
We try to boot boot2qt image through Qt for device creation (Linux). But it does not work.
It worked fine with Colibri-iMX6_LXDE-Image_2.7, but now with Colibri-iMX6_LXDE-Image_2.8.6 it doesn’t work.
When we try to downgrade to Colibri-iMX6_LXDE-Image_2.7 and to follow the steps mentioned in TOradex:
  1. env default -a
  2. saveenv
it also does not work.
When I flashed Colibri-iMX6_LXDE-Image_2.8.6 I used Easy Installer. But when I turn on the device it does not boot.
Could you share a boot log in text format, please?
Thanks and best regards,
