I am trying to reprogram an Apalis iMX8QM 4GB WB IT module but cannot get the Easy Installer to start. I tested the same procedure on a different module and it works perfectly.
I noticed that the module that doesn’t work has some error messages in the Console and extra text relating to “Setting bus to 2”, both of which do not appear on a working module. I’ve copied the Console output below.
Any ideas on how I can reprogram this module?
Thanks!
U-Boot 2020.04-5.7.1+git.33bb8e968332 (Sep 06 2022 - 15:34:09 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.1C, Serial# 07239463
BuildInfo:
- SCFW 216a2c2e, SECO-FW c9de51c0, IMX-MKIMAGE 6a315dbc, ATF 2fa8c63
- U-Boot 2020.04-5.7.1+git.33bb8e968332
switch to partitions #0, OK
Detect USB boot. Will enter fastboot mode!
Net: eth0: ethernet@5b040000
Fastboot: Normal
Setting bus to 2
Error writing the chip: -110
Error writing the chip: 5
Boot from USB for mfgtools
*** Warning - Use default environment for mfgtools
, using default environment
Run bootcmd_mfg: select_dt_from_module_version && fastboot 0
We are in is_imx8
Getting phy ctrl
Hi @aunt_enna,
When you put your module in recovery mode and run the recovery script (“recovery-linux.sh” or “recovery-windows.bat”), does it works without errors?
The log you showed, is it from the Toradex Easy Installer trying to boot?
Reference: Loading Toradex Easy Installer | Toradex Developer Center
Hiago.
Unfortunately, it does not.
Yes, that is the log that appears on the Apalis module in recovery mode when running “recovery-windows.bat”.
Hi @aunt_enna,
Sorry, I meant: when you run the “recovery-windows.bat” script itself output errors on your host PC or the errors you are seeing are only showing when you try to boot the module?
Hiago.
The recovery-windows.bat script locates the module, downloads the installer, but then shows errors, see below:
Hi @aunt_enna,
Thanks for sharing the logs. Which version of Torizon Easy Installer are you using? And the same does not happen with other modules, am I correct?
Hiago.
The ZIP file I downoaded was named: Apalis-iMX8_ToradexEasyInstaller_5.7.1+build.13
And, yes, this behavior does not appear with other modules – I am able to enter Recovery Mode and use the Easy Installer.
Thanks!
Hi @aunt_enna,
Sorry for the delay.
In this case, I suggest you contact the Sales manager you were in contact with to check if you can change this module for a new one (RMA). This should be the case here. Let me know if I can help you in any way.
Hiago.
