Unable to build the image target that contains all Qt5 packages
Hello Sir/Madam,
I want to build the HMI using Qt for Apalis Evaluation Test Board V1.1A , SoM: Apalis iMX6 Quad 2GB.
I am following the link as mentioned below:
  1. Getting Started with Qt
  2. Qt Creator to cross compile - Embedded Linux
Following to build with Open Embedded layers. But while building the image target that contains all Qt5 packages
build] $ bitbake -k angstrom-qt5-x11-image
The error is mentioned below
user@BLTSP01121B:~/oe-core/build$ bitbake -k angstrom-qt5-x11-image
Loading cache: 100% |#####################################################################################################################################| Time: 0:00:00
Loaded 4243 entries from dependency cache.
**ERROR: Nothing PROVIDES 'angstrom-qt5-x11-image'. Close matches:
  qt5-x11-image**
Request your assistance for the same
**Build Configuration:**
BB_VERSION           = "1.40.0"
BUILD_SYS            = "x86_64-linux"
NATIVELSBSTRING      = "universal"
TARGET_SYS           = "arm-tdx-linux-gnueabi"
MACHINE              = "apalis-imx6"
DISTRO               = "tdx-x11"
DISTRO_VERSION       = "2.6-snapshot-20190807"
TUNE_FEATURES        = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU           = "hard"
meta-toradex-nxp     = "HEAD:cf24e18cc50c2f0cab6b44fd3f03fa39cfca4e9f"
meta-freescale       = "HEAD:b73854c078b0a174613135b60da3377a1055f477"
meta-freescale-3rdparty = "HEAD:c4b5ac6b20e4245ce0630e9197313aaef999a331"
meta-toradex-tegra   = "HEAD:057c3d173949d803c150ffe14338554845fec63c"
meta-toradex-bsp-common = "HEAD:3fa96f28bb30643cac3b8a49d3abd7c976acb704"
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python          = "HEAD:9b3b907f30b0d5b92d58c7e68289184fda733d3e"
meta-lxde            = "HEAD:91516dbc14d41613367a75048fbabaf78f3b1a12"
meta-browser         = "HEAD:6386d9aff52adba2c12a83a631355559b394d05e"
meta-qt5             = "HEAD:81937713f774d7dea854b22987b3ef1ab1f1cdbe"
meta-qt5-extra       = "HEAD:641aabf595c78702d16c99d1191a4ac655472ff8"
meta-rust            = "HEAD:0621067c560f6e3e1a4c4c08ac173393bbafad5c"
meta-freescale-distro = "HEAD:4a244af3993ae662624c6f615464e6806cc719a2"
meta-toradex-demos   = "HEAD:5f15f53ed7022e7cadd4b9bfb199d4bc2e66c0db"
meta-toradex-distro  = "HEAD:ba6db37ece74e40c20b8519d4a69a721dd2bf723"
meta-poky            = "HEAD:b36886d9c06961420169842faeb060a31078f6e9"
meta                 = "HEAD:f162d5bfe6eaeca24f441c83c87252c8d05744fc"
Thank you in advance
Hi @amar
I imagine you are compiling the branch LinuxImage3.0, which is based on poky and not more on Angstrom. That’s why you are getting the error above.
We will soon update the QT creator article and write the correct command for compilation which is the following:
bitbake -k qt5-x11-image
Hi @jaski.tx ,
Thank you for the feedback, good day ahead
Amar V
You are welcome.
Have a nice day too.
