Ubuntu 18.04 LTS on Host System
Can you please help us in selecting the Host PC Linux OS Version of Ubuntu which can be used commonly for below Modules
Colibri VF61 256MB V1.2A
Colibri iMX6ULL 512MB IT/V1.1A
Colibri iMX7 Dual 512MB V1.1D
We want to migrate from Wince to linux so we want your suggestion before starting.
Can we develop applications for above modules in the same PC
hi @zecons
Ubuntu 18.04 LTS 64-bit is good choice for beginners to develop and deploy applications using Linux.
What kind of applications do you want to build? Which language or framework (graphic, …) do you want to use?
Embedded applications on Modules
Language : C/C++
Graphics Framework : Using GTK+ (or) Qt
Our basic question is can we develop applications for all the above mentioned Toradex module using same Host PC
Wether Toradex Linux SDK’s are supported in Ubuntu 18.04 LTS 64-bit
Thanks for the Information.
Our basic question is can we develop applications for all the above mentioned Toradex module using same Host PC Wether Toradex Linux SDK’s are supported in Ubuntu 18.04 LTS 64-bit
Yes, you can develop Applications for the Toradex modules using Ubuntu 18.04 and the SDK are supported.
Please note, that depending on your application, you might need to install additional packages on your host for development.
