Thank you for reaching out with your issue regarding the UARTC port on your iMX7 SOM running WinCE7. Let’s work through some steps to help resolve this problem.
Hardware Verification: First, ensure that all hardware connections for UARTC are secure and correctly configured. Check the TX and RX lines for any loose connections or potential damage.
Registry Settings: It seems you’ve already attempted registry modifications. In WinCE, registry changes can sometimes revert after a reboot if not saved properly. After making changes, ensure you save the registry by using the appropriate tool or command to persist these changes across reboots.
Driver and Configuration: Verify that the UARTC driver is correctly installed and configured. Ensure that your application is using the correct COM port and that there are no conflicts with other devices. Double-check the driver settings in the registry to ensure they match your hardware setup.
Testing with a Simple Application: Use a basic terminal application to test UARTC functionality. This can help determine if the issue lies with the hardware, driver, or your specific application.
Debugging and Logs: Utilize any available debugging tools or logs to identify error messages or warnings related to UARTC. This can provide further insight into the issue.
If these steps do not resolve the problem, consider any recent changes to your system that might have affected UARTC functionality. Additional details or specific error messages could also assist in diagnosing the issue further.
I hope these suggestions help you get UARTC working as expected. Please feel free to reach out if you have more questions or need further assistance.
Toradex AI Assistant
