I am trying to enable UART 5 on the Colibri Evaluation Board v3.2 working with iMX7D (1gb). I’ve already modified the device tree applying these changes:
diff --git a/arch/arm/boot/dts/imx7-colibri.dtsi b/arch/arm/boot/dts/imx7-colibri.dtsi
index 348d98e110fc3..3b218e92ef76f 100644
--- a/arch/arm/boot/dts/imx7-colibri.dtsi
+++ b/arch/arm/boot/dts/imx7-colibri.dtsi
@@ -668,7 +667,6 @@
pinctrl-0 = <&pinctrl_uart2>;
assigned-clocks = <&clks IMX7D_UART2_ROOT_SRC>;
assigned-clock-parents = <&clks IMX7D_OSC_24M_CLK>;
- uart-has-rtscts;
fsl,dte-mode;
@@ -680,6 +678,14 @@
fsl,dte-mode;
+&uart5 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_uart5>;
+ assigned-clocks = <&clks IMX7D_UART5_ROOT_SRC>;
+ assigned-clock-parents = <&clks IMX7D_OSC_24M_CLK>;
+ fsl,dte-mode;
&usbotg1 {
dr_mode = "otg";
@@ -1035,6 +1030,13 @@
+ pinctrl_uart5: uart5-grp {
+ fsl,pins = <
+ MX7D_PAD_I2C2_SCL__GPIO4_IO10 0x79
+ MX7D_PAD_I2C2_SDA__GPIO4_IO11 0x79
pinctrl_usbc_det: gpio-usbc-det {
fsl,pins = <
MX7D_PAD_ENET1_CRS__GPIO7_IO14 0x14
diff --git a/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi b/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi
index 2796810426285..8555833782295 100644
--- a/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi
+++ b/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi
@@ -150,6 +150,10 @@
+&uart5 {
+ status = "okay";
&usbotg1 {
extcon = <&extcon_usbc_det>, <&extcon_usbc_det>;
vbus-supply = <®_usbh_vbus>;
After compiling and installing the image, with the applied changes, then I open the JP17 and JP19 to wire the SODIMM pins 88 and 86 to TXD and RXD respectively.
However if I connect a USB to serial cable to the bottom UART connector (X25) with my PC I can’t see any messages sent or received (I am using screen with /dev/ttymx4 configured with baudrate 115200).
Kernel Version: Linux colibri-imx7-emmc 5.4.115-5.3.0-devel+git.dbdbcabf0f98 #1 SMP Tue Jul 6 08:47:10 UTC 2021 armv7l armv7l armv7l GNU/Linux
Let me know if you need any further information.
