UART5 use Colibri T30
Hello Toradex Team,
I want to use UART5 on the Colibri T30 (Pin 79+Pin 97).
unfortunately I can not use the port. It is also not displayed in the terminal.
I have set the pins accordingly in the GPIO configurator.
Would be very nice if you could help me.
Best regards
Saphymo
@Saphymo,
Could you please this : https://developer.toradex.com/knowledge-base/serial-ports#Add_more_Ports_on_Tegra_Modules and let us know if it doesn’t help.
Thank you.
Thank you very much. This helps me.
Best regards
Saphymo
Best regards
Saphymo
