@henrique.tx is currently in vacation. I’ll reproduce his setup on my side to check for the following:
I’ll come back to you up to Thursday on this topic.
About your other question:
The answer is no. If you look at the datasheet (https://docs.toradex.com/101770-apalis-imx6-datasheet.pdf) table 5-33 you can see that these pins could also be used as RX/TX. They were the chosen ones due to availability on his setup but it should work normally with pins 134 and 136.
We cannot test on pins 185 and 187 to verify that it works exactly like you do. On pins 134 and 136 in every test and configuration still does not work and this suggests that these pins cannot be used with hardware flow control.
We have decided to make a hardware change to our board.
We used UART2 instead of UART3. This modification takes a lot of work but we have verified that the UART2 works with the hardware flow control without any problems.
Thanks for the update. I’ll forward this to our team for them to check if there could a problem with these two specific pins as we’ve been able to control them with pins 185 and 187. I’m sorry that you need to pass through this rework.
Please feel free to come back again if you have any other issues, we’ll be glad to help.
