Can you please share all details like how you are testing and what exact parameter passing while running test application.
Are you facing same error with other UART port?
Please note we have not done any throughput test.
here below is the output we quickly try testing in loopback with uart2 on Apalis iMX6Q
root@apalis-imx6:~# linux-serial-test -s -e -p /dev/ttymxc1 -b 3000000
Linux serial test app
/dev/ttymxc1: count for this session: rx=1759827, tx=1764945, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=1760850, tx=1760850, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=3540128, tx=3542175, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=3540128, tx=3539104, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=5320429, tx=5323500, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=5320429, tx=5320429, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=7099707, tx=7104825, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=7100730, tx=7100730, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=8881032, tx=8882055, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=8881032, tx=8878984, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=10662357, tx=10667475, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=10663380, tx=10663380, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=12437539, tx=12440610, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=12437539, tx=12437539, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=14207603, tx=14209650, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=14207603, tx=14206579, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=15977667, tx=15978690, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=15977667, tx=15975619, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=17746707, tx=17751825, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=17747730, tx=17747730, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=19515747, tx=19516770, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=19515747, tx=19513699, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=21280697, tx=21285810, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=21281715, tx=21281715, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=23048708, tx=23050755, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=23048708, tx=23047684, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
/dev/ttymxc1: count for this session: rx=24814677, tx=24819795, rx err=0
/dev/ttymxc1: TIOCGICOUNT: ret=0, rx=24815700, tx=24815700, frame = 0, overrun = 0, parity = 0, brk = 0, buf_overrun = 0
Ritesh Kumar
