Please note that on our Ixora datasheet page 28 by UART1_RS232_TXD resp. UART1_RS232_RXD we mean from the module’s side so you are looking at connecting your cables as follows:
Thanks marcel.tx for confirmation and that was what I did initially but the board just crashed something like Japanese words as following :
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 16:17:43
Press CTRL-A Z for help on special keys
�!�!������=!;!!�����������}='-�-eO忓���i�ky��J��=%%57��ڔ��-�忿��ue�ݽ�-�忟��sYgAYwoy�����sYgAYwoy���U-#1�753='뿿5#-#%5##�/5'���}='-�����-eO�����K.7.1ww[��-%-#1�����-Պ#�9!%%=#7��i�kl+����y��彯U�ۅ!�������������13�7;��59;���k'�����������������������o勿
And curiously that the “irregular” setup was the only one with which I could see the readable output from the board but without being able to interact with it (i.e. to hit any key to interrupt the boot) since its RxD signal was not correctly wired :
OPTIONS: I18n
Port /dev/ttyUSB0, 16:18:58
Industrial temperature grade DDR3 timings.
Trying to boot from MMC1
U-Boot 2016.11-1.7.0+gf4db39ecb6 (Jul 30 2018 - 16:50:57 +0200)
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 2 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
Using default environment
In: serial_mxc
Out: serial_mxc
Err: serial_mxc
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 10486824
Net: using PHY at 7
FEC [PRIME]
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
MMC: no card present
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
583 bytes read in 11 ms (51.8 KiB/s)
## Executing script at 17000000
reading /tezi.itb
21054164 bytes read in 591 ms (34 MiB/s)
## Loading kernel from FIT Image at 12200000 ...
Using 'config@1' configuration
Trying 'kernel@1' kernel subimage
Description: Linux Kernel 4.1
Type: Kernel Image
Compression: uncompressed
Data Start: 0x122000dc
Data Size: 5343320 Bytes = 5.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x11000000
Entry Point: 0x11000000
Hash algo: md5
Hash value: 4194601560c21ef73d9a9f415fbf0f53
Verifying Hash Integrity ... md5+ OK
## Loading ramdisk from FIT Image at 12200000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: SquashFS RAMdisk
Type: RAMDisk Image
Data Start: 0x12718a1c
Data Size: 15659008 Bytes = 14.9 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: md5
Hash value: 55f3d30f4f689acf470ada9d0cf4b360
## Loading fdt from FIT Image at 12200000 ...
Trying 'fdt@1' fdt subimage
Description: Apalis iMX6 Device Tree
Type: Flat Device Tree
Data Start: 0x13607ae4
Data Size: 50361 Bytes = 49.2 KiB
Architecture: ARM
Hash algo: md5
Hash value: 67b35a20ece1bd6c1c0639fed8dc7b47
Booting using the fdt blob at 0x13607ae4
Loading Kernel Image ... OK
Loading Device Tree to 2fff0000, end 2ffff4b8 ... OK
Starting kernel ...
[ 0.912718] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[ 1.435604] imx6q-pcie 1ffc000.pcie: phy link never came up
[ 1.441229] imx6q-pcie 1ffc000.pcie: failed to initialize host
[ 1.451689] rtc-ds1307 1-0068: hctosys: unable to read the hardware clock
Running /etc/rc.local...
Apalis-iMX6_ToradexEasyInstaller_1.7-20180731
Welcome to Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently the
installer does not have a serial console interface. You can use the
Toradex Easy Installer through any of the available display interfaces
using USB mouse/keyboard or via network using VNC. Use:
# ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
I think maybe there’s some HW problem with the Apalis iMX6 module !?!?
The signals on X22 went through a RS232 transceiver and are not CMOS level UART signals.
Your cabling looks like you might use a CMOS level converter to USB which might explain the strange behavior. So what do you use between the Ixora X22 and your PC’s connector?
