I managed by reflashing the U-Boot and the rootfs using only the Apalis v2.6.1 image from your website, without including the NVIDIA JetPack rootfs. I then retried to reflash the device with the “Installing NVIDIA JetPack with L4T on Apalis TK1” procedure and I get the following kernel messages:
U-Boot 2015.04 (Sep 29 2016 - 22:55:33)
TEGRA124
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x12000000-0x12010000
tegra-pcie: non-prefetchable memory: 0x13000000-0x20000000
tegra-pcie: prefetchable memory: 0x20000000-0x40000000
tegra-pcie: 2x1, 1x1 configuration
tegra-pcie: probing port 1, using 1 lanes
In: serial
Out: serial
Err: serial
Model: Toradex Apalis TK1 2GB V1.0B, Serial# 02822863
Net: e1000: no NVM
e1000#0
Hit any key to stop autoboot: 1 0
Booting from internal eMMC chip...
reading tegra124-apalis-eval.dtb
49196 bytes read in 19 ms (2.5 MiB/s)
reading uImage
6266384 bytes read in 157 ms (38.1 MiB/s)
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Angstrom/3.10.40+gitr0e41a93380f
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 6266320 Bytes = 6 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Loading Kernel Image ... OK
Using Device Tree in place at 82000000, end 8200f02b
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40-V2.6.1b1+g0e41a93 (linuxdev@linuxdev.toradex.int) (gcc version 5.2.1 20151005 (Linaro GCC 5.2-2015.11-2) ) #1 SMP PREEMPT Thu Sep 29 22:57:04 CEST 2016
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: apalis-tk1, model: Toradex Apalis TK1, serial: 0
[ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: fa5ff000 - fb7fefff
[ 0.000000] 2nd Framebuffer: fb7ff000 - ffffefff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: 00000000 - 00000000
[ 0.000000] cma: CMA: reserved 16 MiB at ae800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] DTS File Name: /build/linuxdev/oe-core_V2.6.1/build/tmp-glibc/work-shared/apalis-tk1/kernel-source/arch/arm/boot/dts/tegra124-apalis-eval.dts
[ 0.000000] Tegra12: CPU Speedo value 2252, Soc Speedo value 2180, Gpu Speedo value 2046
[ 0.000000] Tegra12: CPU Speedo ID 5, Soc Speedo ID 0, Gpu Speedo ID 1
[ 0.000000] Tegra12: CPU Process ID 0,Soc Process ID 1,Gpu Process ID 0
[ 0.000000] Tegra Revision: A01 SKU: 0x87 CPU Process: 0 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1044000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 372000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 756000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 756000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 480000000
[ 0.000000] Lowering se maximum rate from 600000000 to 480000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 480000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 408000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2065500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra12_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1e2d000 s15168 r8192 d13504 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 499215
[ 0.000000] Kernel command line: lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 ip=off root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait igb_mac=00:14:2d:2b:12:cf consoleblank=0 no_console_suspend=1 console=tty1 console=ttyS0,115200n8 debug_uartport=lsport,0 video=tegrafb0:640x480-16@60 fbcon=map:1
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1955MB = 1955MB total
[ 0.000000] Memory: 1954560k/1954560k available, 142588k reserved, 1224696K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b857e0 (11766 kB)
[ 0.000000] .init : 0xc0b86000 - 0xc0c04b40 ( 507 kB)
[ 0.000000] .data : 0xc0c06000 - 0xc0d5eb98 (1379 kB)
[ 0.000000] .bss : 0xc0d5eb98 - 0xc0dfc8f4 ( 632 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.002577] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[ 0.002633] pid_max: default: 32768 minimum: 301
[ 0.002922] Mount-cache hash table entries: 512
[ 0.022181] Initializing cgroup subsys debug
[ 0.022219] Initializing cgroup subsys freezer
[ 0.022296] CPU: Testing write buffer coherency: ok
[ 0.022378] ftrace: allocating 31534 entries in 62 pages
[ 0.062263] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.062304] Setting up static identity map for 0xc084d0d8 - 0xc084d174
[ 0.066299] ftrace: Allocated trace_printk buffers
[ 0.072932] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.075944] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.078984] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.079167] Brought up 4 CPUs
[ 0.079241] SMP: Total of 4 processors activated.
[ 0.079258] CPU: All CPU(s) started in SVC mode.
[ 0.080137] devtmpfs: initialized
[ 0.088216] pinctrl core: initialized pinctrl subsystem
[ 0.088543] regulator-dummy: no parameters
[ 0.089220] NET: Registered protocol family 16
[ 0.091272] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.092538] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[ 0.093902] console [pstore-1] enabled
[ 0.093939] ramoops: attached 0x200000@0xfa3ff000, ecc: 0/0
[ 0.094297] cpuidle: using governor ladder
[ 0.094319] cpuidle: using governor menu
[ 0.097637] apalis_tk1_camera_auxdata: update camera lookup table.
[ 0.106733] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[ 0.107099] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.113972] Wake16 for irq=34
[ 0.116389] Wake58 for irq=81
[ 0.116437] Wake41 for irq=129
[ 0.116455] Wake43 for irq=129
[ 0.116499] Wake40 for irq=53
[ 0.116515] Wake42 for irq=53
[ 0.220880] Selecting UARTA as the debug console
[ 0.220927] The debug console clock name is uarta
[ 0.222338] pmu_board_info.board_id = 0
[ 0.222359] PMU board id 0x0000 is not supported
[ 0.222903] Clear bootloader IO dpd settings
[ 0.223068] Loading Apalis TK1 EMC tables.
[ 0.223295] tegra: pll_m is selected as scalable EMC clock source
[ 0.223338] Lowering emc maximum rate from 1200000000 to 924000000
[ 0.223364] tegra: validated EMC DFS table
[ 0.223432] apalis_tk1_edp_init: CPU regulator 12500 mA
[ 0.476031] apalis_tk1_edp_init: GPU regulator 11400 mA
[ 0.476983] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[ 0.477003] swapper/0 isomgr_init(): max_iso_bw=7392000KB[ 0.559966] platform tegradc.0: IOVA linear map 0xfa5ff000(1200000)
[ 0.563274] platform tegradc.0: IOVA linear map 0xfb7ff000(4800000)
[ 0.568207] platform tegradc.1: IOVA linear map 0xfa5ff000(1200000)
[ 0.571501] platform tegradc.1: IOVA linear map 0xfb7ff000(4800000)
[ 0.571789] tegra11_soctherem_oc_int_init(): OC interrupts enabled successful
[ 0.571991] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.572021] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.572293] mc-err: Started MC error interface!
[ 0.582625] bio: create slab at 0
[ 0.583782] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[ 0.583816] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[ 0.583949] +V3.3_MXM: 3300 mV
[ 0.584495] vgaarb: loaded
[ 0.584921] SCSI subsystem initialized
[ 0.585276] usbcore: registered new interface driver usbfs
[ 0.585357] usbcore: registered new interface driver hub
[ 0.585469] usbcore: registered new device driver usb
[ 0.587054] Wake18 for irq=118
[ 0.588136] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x05
[ 0.588165] as3722 4-0040: Device version 1V1 and platform version 1V2
[ 0.588189] as3722 4-0040: Final OTP version 1V2
[ 0.589144] Wake18 for irq=118
[ 0.591667] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[ 0.591864] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.591923] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.591978] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.592009] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.592039] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.592069] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.592122] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.592151] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.592181] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.592209] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.592239] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.592268] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.592297] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.592371] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.592401] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.592448] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.592479] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.592508] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.592540] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.592569] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.592598] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.592627] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.592656] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[ 0.592685] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.592714] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[ 0.592743] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[ 0.592773] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[ 0.592802] as3722-regulator as3722-regulator.0: Consumer c16 does not have device name
[ 0.592837] as3722-regulator as3722-regulator.0: Consumer c19 does not have device name
[ 0.592866] as3722-regulator as3722-regulator.0: Consumer c20 does not have device name
[ 0.592895] as3722-regulator as3722-regulator.0: Consumer c21 does not have device name
[ 0.592924] as3722-regulator as3722-regulator.0: Consumer c22 does not have device name
[ 0.592998] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.593028] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.593084] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.593113] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.593142] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.593170] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.593199] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.593229] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.593258] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.593287] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.593316] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.593367] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.593455] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.593487] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.593516] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.593547] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.593599] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.593647] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.593677] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.593727] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.594540] +VDD_CPU_AP: 650 <--> 1300 mV at 1000 mV 3500 mA
[ 0.595160] +VDD_CORE: applied init 1150000uV constraint
[ 0.595631] +VDD_CORE: 700 <--> 1350 mV at 1150 mV 3500 mA
[ 0.596652] +V1.35_VDDIO_DDR(sd2): 1350 mV
[ 0.596963] as3722-sd3: no parameters
[ 0.597267] +V1.05: 1050 mV
[ 0.598116] +V1.8: 1800 mV
[ 0.598455] +VDD_GPU_AP: applied init 1000000uV constraint
[ 0.599215] +VDD_GPU_AP: 650 <--> 1200 mV at 1000 mV 3500 mA
[ 0.599710] +V1.05_AVDD: 1050 mV at 300 mA
[ 0.600394] VDDIO_SDMMC1: 1800 <--> 3300 mV at 3300 mV at 150 mA
[ 0.601065] +V1.2: 1200 mV at 150 mA
[ 0.602138] +V1.05_RTC: 1000 mV at 150 mA
[ 0.602464] AVDD_LVDS0_PLL: 1800 mV at 150 mA
[ 0.602812] as3722-ldo5: at 150 mA
[ 0.603148] VDDIO_SDMMC3: 1800 <--> 3300 mV at 150 mA
[ 0.603481] as3722-ldo7: at 150 mA
[ 0.604302] +V3.3_ETH(ldo9): 3300 mV at 300 mA
[ 0.604949] +V3.3_ETH(ldo10): 3300 mV at 300 mA
[ 0.605290] +V1.8_VPP_FUSE: 1800 mV at 150 mA
[ 0.606264] Linux video capture interface: v2.00
[ 0.606319] pps_core: LinuxPPS API ver. 1 registered
[ 0.606338] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ 0.606384] PTP clock support registered
[ 0.607159] Advanced Linux Sound Architecture Driver Initialized.
[ 0.607917] +V1.05_AVDD_HDMI_PLL: 1050 mV
[ 0.607969] +V1.05_AVDD_HDMI_PLL: supplied by +V1.05
[ 0.608172] reg-fixed-sync-voltage 2.regulator: Consumer c7 does not have device name
[ 0.608205] reg-fixed-sync-voltage 2.regulator: Consumer c8 does not have device name
[ 0.608234] reg-fixed-sync-voltage 2.regulator: Consumer c9 does not have device name
[ 0.608264] reg-fixed-sync-voltage 2.regulator: Consumer c10 does not have device name
[ 0.608294] reg-fixed-sync-voltage 2.regulator: Consumer c11 does not have device name
[ 0.608331] reg-fixed-sync-voltage 2.regulator: Consumer c15 does not have device name
[ 0.608360] reg-fixed-sync-voltage 2.regulator: Consumer c16 does not have device name
[ 0.608389] reg-fixed-sync-voltage 2.regulator: Consumer c17 does not have device name
[ 0.608418] reg-fixed-sync-voltage 2.regulator: Consumer c18 does not have device name
[ 0.608968] +V3.3: 3300 mV
[ 0.609204] reg-fixed-sync-voltage 3.regulator: Consumer c3 does not have device name
[ 0.609326] 5V_SW: 5000 mV
[ 0.609612] VCC_USBO1: 5000 mV
[ 0.609926] VCC_USBH(2A|2C|2D|3|4): 5000 mV
[ 0.610084] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
[ 0.610116] reg-fixed-sync-voltage 6.regulator: Consumer c2 does not have device name
[ 0.610265] BKL1_ON: 3300 mV
[ 0.613033] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is connected
[ 0.615275] tegra: failed to map regulator to power detect cell pwrdet_cam(-517)
[ 0.615664] tegra: failed regulators mapping - io power detection is left always on
[ 0.615698] Switching to clocksource arch_sys_counter
[ 0.636970] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.637135] nvmap_page_pool_init: Total MB RAM: 1924
[ 0.637158] nvmap_page_pool_init: nvmap page pool size: 61592 pages (240 MB)
[ 0.637303] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.637462] iram: dma coherent mem declare 0x40001000,258048
[ 0.638301] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[ 0.638461] nvmap:inner cache maint threshold=2097152
[ 0.647509] Wake39 for irq=52
[ 0.647606] tegra-otg tegra-otg: otg transceiver registered
[ 0.647949] NET: Registered protocol family 2
[ 0.648618] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.648841] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.649033] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.649091] TCP: reno registered
[ 0.649116] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.649171] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.649456] NET: Registered protocol family 1
[ 0.649850] RPC: Registered named UNIX socket transport module.
[ 0.649874] RPC: Registered udp transport module.
[ 0.649893] RPC: Registered tcp transport module.
[ 0.649911] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.650201] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 0.655472] host1x host1x: initialized
[ 0.656373] CPU PMU: probing PMU on CPU 0
[ 0.656407] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.656991] tegra_throttle : init passed
[ 0.657104] Tegra cpuquiet initialized: disabled
[ 0.657227] cpu-tegra: init EDP limit: 2065 MHz
[ 0.658175] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.658556] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.658803] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[ 0.659048] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.659076] soctherm: Suspend feature CANNOT be enabled when any OC alarm is enabled
[ 0.660464] bounce pool size: 64 pages
[ 0.661657] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.662087] NFS: Registering the id_resolver key type
[ 0.662133] Key type id_resolver registered
[ 0.662155] Key type id_legacy registered
[ 0.662183] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.662787] NTFS driver 2.1.30 [Flags: R/O].
[ 0.663076] fuse init (API version 7.22)
[ 0.663441] msgmni has been set to 1457
[ 0.665122] io scheduler noop registered (default)
[ 0.866388] PCIE: port 0: link down, retrying
[ 4.002310] i2c /dev entries driver
[ 4.006673] virtual_init
[ 4.010956] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[ 4.014830] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.022902] tegra_dtv_probe: probing dtv.
[ 4.027001] setup_stream: bufsize = 4096, bufnum = 4
[ 4.032039] ar0832_init: ++
[ 4.035303] i2c-core: driver [max77387] using legacy suspend method
[ 4.041588] i2c-core: driver [max77387] using legacy resume method
[ 4.047854] i2c-core: driver [as364x] using legacy suspend method
[ 4.053965] i2c-core: driver [as364x] using legacy resume method
[ 4.060102] [IMX135] sensor driver loading
[ 4.064252] [IMX179] sensor driver loading
[ 4.068429] [IMX185] sensor driver loading
[ 4.072612] [imx132] sensor driver loading
[ 4.076804] [AR0330] sensor driver loading
[ 4.080955] [ar0261] sensor driver loading
[ 4.085107] [AR1335] sensor driver loading
[ 4.089285] [ov4689] sensor driver loading
[ 4.093589] usbcore: registered new interface driver uvcvideo
[ 4.099352] USB Video Class driver (1.1.1)
[ 4.103865] zram: Created 1 device(s) ...
[ 4.108463] tegra_wdt tegra_wdt.0: last reset is due to watchdog timeout
[ 4.115361] WDT heartbeat enabled on probe
[ 4.119477] tegra_wdt_probe done
[ 4.122735] otg state changed: SUSPEND --> PERIPHERAL
[ 4.128190] sdhci: Secure Digital Host Controller Interface driver
[ 4.134403] sdhci: Copyright(c) Pierre Ossman
[ 4.138784] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.144748] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 4.155684] sdhci-tegra sdhci-tegra.3: Speedo value 2180
[ 4.161022] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 4.170670] mmc0: no vqmmc regulator found
[ 4.174797] mmc0: no vmmc regulator found
[ 4.178825] mmc0: Invalid maximum block size, assuming 512 bytes
[ 4.184866] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 4.218811] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 4.226949] sdhci-tegra sdhci-tegra.0: Speedo value 2180
[ 4.232289] sdhci-tegra sdhci-tegra.0: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 4.241810] mmc1: no vqmmc regulator found
[ 4.245936] mmc1: no vmmc regulator found
[ 4.249962] mmc1: Invalid maximum block size, assuming 512 bytes
[ 4.256002] sysedp_create_consumer: unable to create sdhci-tegra.0, no consumer_data for sdhci-tegra.0 found
[ 4.289810] mmc1: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ 4.297978] sdhci-tegra sdhci-tegra.2: Speedo value 2180
[ 4.303328] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 4.312758] mmc2: no vqmmc regulator found
[ 4.316910] mmc2: no vmmc regulator found
[ 4.320939] mmc2: Invalid maximum block size, assuming 512 bytes
[ 4.326013] mmc0: BKOPS_EN bit is not set
[ 4.328440] mmc0: new high speed DDR MMC card at address 0001
[ 4.328659] mmcblk mmc0:0001: Card claimed for testing.
[ 4.328822] mmcblk0: mmc0:0001 016G30 14.6 GiB
[ 4.328973] mmcblk0boot0: mmc0:0001 016G30 partition 1 4.00 MiB
[ 4.329118] mmcblk0boot1: mmc0:0001 016G30 partition 2 4.00 MiB
[ 4.329243] mmcblk0rpmb: mmc0:0001 016G30 partition 3 4.00 MiB
[ 4.330079] mmcblk0: p1 p2
[ 4.331849] mmcblk0boot1: unknown partition table
[ 4.332904] mmcblk0boot0: unknown partition table
[ 4.376514] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
[ 4.409809] mmc2: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 4.420247] tegra-se tegra12-se: tegra_se_probe: complete
[ 4.425841] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.433359] usbcore: registered new interface driver usbhid
[ 4.438956] usbhid: USB HID core driver
[ 4.443189] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 4.527373] usbcore: registered new interface driver snd-usb-audio
[ 4.534527] tegra_offload_platform probe successfull.
[ 4.541575] succefully registered offload opstegra30_avp_audio_platform_probe successful.
[ 4.550610] sgtl5000 4-000a: sgtl5000 revision 0x11
[ 4.555940] 4-000a: 1200 mV normal
[ 4.560165] sgtl5000 4-000a: Using internal LDO instead of VDDD
[ 4.571694] tegra-snd-apalis-tk1-sgtl5000 tegra-snd-apalis-tk1-sgtl5000.0: sgtl5000 <-> tegra30-i2s.2 mapping ok
[ 4.582357] tegra-snd-apalis-tk1-sgtl5000 tegra-snd-apalis-tk1-sgtl5000.0: dit-hifi <-> tegra30-spdif mapping ok
[ 4.594396] oprofile: using timer interrupt.
[ 4.598809] GACT probability NOT on
[ 4.602325] Mirror/redirect action on
[ 4.606005] u32 classifier
[ 4.608727] Actions configured
[ 4.612145] Netfilter messages via NETLINK v0.30.
[ 4.616917] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 4.623417] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 4.630396] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 4.636479] xt_time: kernel timezone is -0000
[ 4.641139] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.646610] arp_tables: (C) 2002 David S. Miller
[ 4.651299] TCP: cubic registered
[ 4.654818] NET: Registered protocol family 10
[ 4.660129] mip6: Mobile IPv6
[ 4.663149] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.668696] sit: IPv6 over IPv4 tunneling driver
[ 4.674276] NET: Registered protocol family 17
[ 4.678819] NET: Registered protocol family 15
[ 4.683317] can: controller area network core (rev 20120528 abi 9)
[ 4.689639] NET: Registered protocol family 29
[ 4.694106] can: raw protocol (rev 20120528)
[ 4.698410] can: broadcast manager protocol (rev 20120528 t)
[ 4.704092] can: netlink gateway (rev 20130117) max_hops=1
[ 4.709695] NET: Registered protocol family 35
[ 4.714937] 8021q: 802.1Q VLAN Support v1.8
[ 4.719183] NET: Registered protocol family 37
[ 4.723686] Key type dns_resolver registered
[ 4.727982] NET: Registered protocol family 41
[ 4.733563] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 4.764812] Registering SWP/SWPB emulation handler
[ 4.769632] last reset is due to watchdog timeout
[ 4.769632]
[ 4.775837] Disabling clocks left on by bootloader:
[ 4.780714] audio_2x
[ 4.783179] audio
[ 4.785380] audio4
[ 4.787668] audio3
[ 4.789954] audio2
[ 4.792242] audio1
[ 4.794530] audio0
[ 4.796912] hdmi_audio
[ 4.799548] entropy
[ 4.801929] dsi2-fixed
[ 4.804748] dsi1-fixed
[ 4.807396] mipi-cal-fixed
[ 4.810382] nor
[ 4.812415] trace
[ 4.814622] sdmmc3_ddr
[ 4.817259] sdmmc1_ddr
[ 4.819961] cclk_lp
[ 4.822341] pll_x_out0
[ 4.824987] pll_m_out1
[ 4.827728] tegra_dvfs: vdd_cpu connected to regulator
[ 4.832928] tegra_dvfs: vdd_core connected to regulator
[ 4.838413] tegra_dvfs: vdd_gpu connected to regulator
[ 4.844527] CPU rate: 696 MHz
[ 5.101562] tegra dvfs: tegra sysfs cap interface is initialized
[ 5.107716] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 5.114825] tegra_actmon.emc: Completed initialization (0)
[ 5.120566] tegra_actmon.avp: Completed initialization (0)
[ 5.126205] tegra_mon.cpu_emc: Completed initialization (0)
[ 5.134518] VCC_USBH(2A|2C|2D|3|4): incomplete constraints, leaving on
[ 5.141082] VCC_USBO1: incomplete constraints, leaving on
[ 5.146544] +V1.05_AVDD_HDMI_PLL: incomplete constraints, leaving on
[ 5.153007] +V1.8_VPP_FUSE: incomplete constraints, leaving on
[ 5.158861] as3722-ldo7: incomplete constraints, leaving on
[ 5.164510] as3722-ldo5: incomplete constraints, leaving on
[ 5.170102] VDDIO_SDMMC1: incomplete constraints, leaving on
[ 5.175877] as3722-sd3: incomplete constraints, leaving on
[ 5.181381] +V3.3_MXM: incomplete constraints, leaving on
[ 5.186851] regulator-dummy: incomplete constraints, leaving on
[ 5.193476] file system registered
[ 5.197791] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 5.204686] android_usb gadget: Number of LUNs=1
[ 5.209355] lun0: LUN: removable file: (no medium)
[ 5.214587] android_maxim14675_set_voltage: max_voltage (vbus) = 5000
[ 5.221093] android_usb gadget: android_usb ready
[ 5.225817] tegra-udc: bind to driver android_usb
[ 5.230757] gpio wake14 for gpio=235
[ 5.234611] input: gpio-keys.3 as /devices/platform/gpio-keys.3/input/input0
[ 5.242369] as3722-rtc as3722-rtc.1: setting system clock to 2016-11-02 15:59:53 UTC (1478102393)
[ 5.251560] ALSA device list:
[ 5.254557] #0: Toradex Apalis TK1 SGTL5000
[ 5.259019] #1: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 5.265994] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 5.277804] JBD2: no valid journal superblock found
[ 5.282811] EXT4-fs (mmcblk0p2): error loading journal
[ 5.288200] List of all partitions:
[ 5.291814] b300 15388672 mmcblk0 driver: mmcblk
[ 5.297187] b301 16384 mmcblk0p1 0002fb4b-01
[ 5.302670] b302 7587840 mmcblk0p2 0002fb4b-02
[ 5.308017] b330 4096 mmcblk0rpmb (driver?)
[ 5.313347] b320 4096 mmcblk0boot1 (driver?)
[ 5.318704] b310 4096 mmcblk0boot0 (driver?)
[ 5.324083] No filesystem could mount root, tried: ext3
[ 5.329492] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
[ 5.337933] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.40-V2.6.1b1+g0e41a93 #1
[ 5.345526] [] (unwind_backtrace+0x0/0x134) from [] (show_stack+0x18/0x1c)
[ 5.354151] [] (show_stack+0x18/0x1c) from [] (panic+0xa4/0x1ec)
[ 5.361908] [] (panic+0xa4/0x1ec) from [] (mount_block_root+0x228/0x23c)
[ 5.370355] [] (mount_block_root+0x228/0x23c) from [] (mount_root+0x110/0x118)
[ 5.379322] [] (mount_root+0x110/0x118) from [] (prepare_namespace+0x150/0x198)
[ 5.388375] [] (prepare_namespace+0x150/0x198) from [] (kernel_init_freeable+0x1b4/0x1c4)
[ 5.398295] [] (kernel_init_freeable+0x1b4/0x1c4) from [] (kernel_init+0x14/0x144)
[ 5.407606] [] (kernel_init+0x14/0x144) from [] (ret_from_fork+0x14/0x20)
[ 5.416137] CPU3: stopping
[ 5.418854] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 3.10.40-V2.6.1b1+g0e41a93 #1
[ 5.426440] [] (unwind_backtrace+0x0/0x134) from [] (show_stack+0x18/0x1c)
[ 5.435062] [] (show_stack+0x18/0x1c) from [] (handle_IPI+0x194/0x1a8)
[ 5.443333] [] (handle_IPI+0x194/0x1a8) from [] (gic_handle_irq+0x84/0x140)
[ 5.452038] [] (gic_handle_irq+0x84/0x140) from [] (__irq_svc+0x40/0x70)
[ 5.460474] Exception stack(0xee289f08 to 0xee289f50)
[ 5.465529] 9f00: ee289f58 00a9b02a 0002a6c0 0002a6c0 c1e4a7d8 00000000
[ 5.473707] 9f20: 370d8e55 00000001 00000000 c0d49654 c0deb9c0 c1e483e8 00000000 ee289f50
[ 5.481882] 9f40: c0308b40 c003dfc4 20000113 ffffffff
[ 5.486944] [] (__irq_svc+0x40/0x70) from [] (tegra_idle_enter_clock_gating+0x58/0x78)
[ 5.496605] [] (tegra_idle_enter_clock_gating+0x58/0x78) from [] (cpuidle_enter_state+0x44/0xec)
[ 5.507132] [] (cpuidle_enter_state+0x44/0xec) from [] (cpuidle_idle_call+0xe8/0x27c)
[ 5.516704] [] (cpuidle_idle_call+0xe8/0x27c) from [] (arch_cpu_idle+0x10/0x40)
[ 5.525758] [] (arch_cpu_idle+0x10/0x40) from [] (cpu_startup_entry+0x190/0x248)
[ 5.534896] [] (cpu_startup_entry+0x190/0x248) from [<80841664>] (0x80841664)
[ 5.542900] CPU2: stopping
[ 5.545619] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 3.10.40-V2.6.1b1+g0e41a93 #1
[ 5.553208] [] (unwind_backtrace+0x0/0x134) from [] (show_stack+0x18/0x1c)
[ 5.561833] [] (show_stack+0x18/0x1c) from [] (handle_IPI+0x194/0x1a8)
[ 5.570107] [] (handle_IPI+0x194/0x1a8) from [] (gic_handle_irq+0x84/0x140)
[ 5.578815] [] (gic_handle_irq+0x84/0x140) from [] (__irq_svc+0x40/0x70)
[ 5.587254] Exception stack(0xee287f08 to 0xee287f50)
[ 5.592314] 7f00: ee287f58 0055331a 000154cc 000154cc c1e417d8 00000000
[ 5.600496] 7f20: 3c35b01c 00000001 00000000 c0d49654 c0deb9c0 c1e3f3e8 00000000 ee287f50
[ 5.608675] 7f40: c0308b40 c003dfc4 20000113 ffffffff
[ 5.613739] [] (__irq_svc+0x40/0x70) from [] (tegra_idle_enter_clock_gating+0x58/0x78)
[ 5.623404] [] (tegra_idle_enter_clock_gating+0x58/0x78) from [] (cpuidle_enter_state+0x44/0xec)
[ 5.633935] [] (cpuidle_enter_state+0x44/0xec) from [] (cpuidle_idle_call+0xe8/0x27c)
[ 5.643512] [] (cpuidle_idle_call+0xe8/0x27c) from [] (arch_cpu_idle+0x10/0x40)
[ 5.652570] [] (arch_cpu_idle+0x10/0x40) from [] (cpu_startup_entry+0x190/0x248)
[ 5.661713] [] (cpu_startup_entry+0x190/0x248) from [<80841664>] (0x80841664)
[ 5.669719] CPU1: stopping
[ 5.672452] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.10.40-V2.6.1b1+g0e41a93 #1
[ 5.680053] [] (unwind_backtrace+0x0/0x134) from [] (show_stack+0x18/0x1c)
[ 5.688692] [] (show_stack+0x18/0x1c) from [] (handle_IPI+0x194/0x1a8)
[ 5.696980] [] (handle_IPI+0x194/0x1a8) from [] (gic_handle_irq+0x84/0x140)
[ 5.705703] [] (gic_handle_irq+0x84/0x140) from [] (__irq_svc+0x40/0x70)
[ 5.714158] Exception stack(0xee285f08 to 0xee285f50)
[ 5.719229] 5f00: ee285f58 00553a15 000154e8 000154e8 c1e387d8 00000000
[ 5.727425] 5f20: 3c35430f 00000001 00000000 c0d49654 c0deb9c0 c1e363e8 00000000 ee285f50
[ 5.735617] 5f40: c0308b40 c003dfc4 20000113 ffffffff
[ 5.740696] [] (__irq_svc+0x40/0x70) from [] (tegra_idle_enter_clock_gating+0x58/0x78)
[ 5.750375] [] (tegra_idle_enter_clock_gating+0x58/0x78) from [] (cpuidle_enter_state+0x44/0xec)
[ 5.760921] [] (cpuidle_enter_state+0x44/0xec) from [] (cpuidle_idle_call+0xe8/0x27c)
[ 5.770507] [] (cpuidle_idle_call+0xe8/0x27c) from [] (arch_cpu_idle+0x10/0x40)
[ 5.779579] [] (arch_cpu_idle+0x10/0x40) from [] (cpu_startup_entry+0x190/0x248)
[ 5.788735] [] (cpu_startup_entry+0x190/0x248) from [<80841664>] (0x80841664)
[ 36.073773] ------------[ cut here ]------------
[ 36.078440] WARNING: at /build/linuxdev/oe-core_V2.6.1/build/tmp-glibc/work-shared/apalis-tk1/kernel-source/kernel/watchdog.c:270 watchdog_timer_fn+0x27c/0x2b8()
[ 36.092898] Watchdog detected hard LOCKUP on cpu 1
[ 36.097544] Modules linked in:
[ 36.100881] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.40-V2.6.1b1+g0e41a93 #1
[ 36.108495] [] (unwind_backtrace+0x0/0x134) from [] (show_stack+0x18/0x1c)
[ 36.117153] [] (show_stack+0x18/0x1c) from [] (warn_slowpath_common+0x5c/0x74)
[ 36.126152] [] (warn_slowpath_common+0x5c/0x74) from [] (warn_slowpath_fmt+0x38/0x48)
[ 36.135757] [] (warn_slowpath_fmt+0x38/0x48) from [] (watchdog_timer_fn+0x27c/0x2b8)
[ 36.145283] [] (watchdog_timer_fn+0x27c/0x2b8) from [] (__run_hrtimer+0x90/0x280)
[ 36.154543] [] (__run_hrtimer+0x90/0x280) from [] (hrtimer_interrupt+0x120/0x2d8)
[ 36.163807] [] (hrtimer_interrupt+0x120/0x2d8) from [] (arch_timer_handler_phys+0x30/0x38)
[ 36.173849] [] (arch_timer_handler_phys+0x30/0x38) from [] (handle_percpu_devid_irq+0x8c/0x194)
[ 36.184323] [] (handle_percpu_devid_irq+0x8c/0x194) from [] (generic_handle_irq+0x34/0x44)
[ 36.194365] [] (generic_handle_irq+0x34/0x44) from [] (handle_IRQ+0x48/0x98)
[ 36.203188] [] (handle_IRQ+0x48/0x98) from [] (gic_handle_irq+0x4c/0x140)
[ 36.211748] [] (gic_handle_irq+0x4c/0x140) from [] (__irq_svc+0x40/0x70)
[ 36.220214] Exception stack(0xee0d7e58 to 0xee0d7ea0)
[ 36.225297] 7e40: 000025ee 00000000
[ 36.233511] 7e60: ff691f00 c061eb28 c0dcbe20 00002edf 1bbf4be1 000076c0 c0cf6384 00000026
[ 36.241723] 7e80: 3ffffcc8 ed101005 00000000 ee0d7ea0 c02fadcc c02fadb4 80000113 ffffffff
[ 36.249944] [] (__irq_svc+0x40/0x70) from [] (__timer_delay+0x3c/0x64)
[ 36.258251] [] (__timer_delay+0x3c/0x64) from [] (panic+0x1d8/0x1ec)
[ 36.266384] [] (panic+0x1d8/0x1ec) from [] (mount_block_root+0x228/0x23c)
[ 36.274948] [] (mount_block_root+0x228/0x23c) from [] (mount_root+0x110/0x118)
[ 36.283949] [] (mount_root+0x110/0x118) from [] (prepare_namespace+0x150/0x198)
[ 36.293036] [] (prepare_namespace+0x150/0x198) from [] (kernel_init_freeable+0x1b4/0x1c4)
[ 36.302990] [] (kernel_init_freeable+0x1b4/0x1c4) from [] (kernel_init+0x14/0x144)
[ 36.312337] [] (kernel_init+0x14/0x144) from [] (ret_from_fork+0x14/0x20)
[ 36.320894] ---[ end trace d948d41c72731047 ]---
Do you have an idea why I get these CPU stop messages?
Jérôme
