U-boot update script
hello!
We have to update the u-boot of apalis-imx6 that are embedded in a cabinet where there is no access to the board via rs232 or USB. The only way is to access through a local ethernet network.
My intention is to update the u-boot using some script that flashes the /dev/mmcblk2boot0 partition somehow.
I have tried to dd u-boot.img directly but it doesn’t work.
How should I do it?
Hi @LordXor !
Which BSP version are you using in this module?
Also, which exact version is the Apalis iMX6 module?
Hi @henrique.tx !
How can I know the BSP version?
I am building a custom image with yocto using the toradex layers dunfell-5.x.y if you mean this.
The IMX6 module is V1.1Y
Hi @LordXor !
Seems like your U-Boot is not in the default location.
Could you please share more information about the setup of your module?
