I try to set the u-boot env via fw_setenv.
On my Tegra board I have these partitions
ls /dev/mmcblk* /dev/mmcblk0 /dev/mmcblk0boot0 /dev/mmcblk0boot1 /dev/mmcblk0p1 /dev/mmcblk0p2 /dev/mmcblk0rpmb
and these versions:
Tegra124 Linux R21.6.0 armhf
This post leads to the default fw_env.config but to an access violation:
http://git.toradex.com/cgit/meta-toradex-tegra.git/tree/recipes-bsp/u-boot/files/tegra124/fw_env.config?h=morty
/dev/mmcblk0boot0 -0x2200 0x2000
This post leads to a different one which leads to CRC warnings and a difference between boot prompt printenv (no changes) and Linux fw_printenv (changes saved):
/dev/mmcblk0 0x80000 0x2000
Can you give me a hint which configuration might be the right one?
regards
Dirk
