U-Boot Issue After Updating Colibri VF61
I followed this document for update vf61 at yocto but after the setupdate and update with U-Boot I read resetting… and my device not start.
I had the flash_mmc.img that I found in Colibri_VF_LinuxImageV2.4Beta1_20150518.tar.bz2 (Index of /files/toradex-dev/uploads/media/Colibri/Linux/Images/old)
Now I have followed this guide for recovery VFxx Recovery Mode but I not have pinout or jump on my viola board so I used the solder solution
  1. Directly on VFxx module
    Shorten the recovery pad. Refer to the picture below: …
But my device is still dead
Can I have a help?
Thank a lot
Michele
I would recommend trying this with a later stable BSP version e.g. 2.7 recently released (equal to 2.7b4).
Thanks you Marcel… but my module is dead… I tried update.sh but nothing response… also with rts and cts … these my steps:
  1. Soldered two point with I read on your document (https://developer.toradex.com/knowledge-base/vfxx-recovery-mode )
  2. Power ON the module
  3. Launch update.sh and wait ( ttyUSB0 115200 with RTS&CTS )
response magic missing 0x000000
Hi Michele
If you are getting
then, you did not get to recovery mode. Do you have another sample of the module? If yes, try this one.
Additionally check your cabling.
Best regards
Hi Jaski thanks for your informations. Unfortunately I not have another module; but I followed your guide and I loaded your uboot img. Why I got this problem? So your documents are wrong and now my device is broken… frankly, I’m stumped also because your devices are not cheap. Please check your web documents
Best regards
Michele
HI Michele
Did you have once working connection to the module? If not, then probably it is a cabling issue or general communication issue.
best regards, Jaski
Hi Michele
Could you send a small picture of your cabling? I think, this will help a lot.
Best regards
