Thank you for reaching out with your question. It sounds like you’re doing some interesting work with your Verdin iMX8MP board and Yocto. Let’s address the issue you’re facing with accessing U-Boot environment variables.
To resolve this, you’ll need to ensure that the configuration file /etc/fw_env.config is correctly set up for your hardware. This file specifies where the U-Boot environment is stored on the flash memory.
For the Verdin iMX8MP, which uses eMMC, the U-Boot environment is typically stored at the end of the first eMMC boot partition. Here’s how you can configure it:
Identify the Correct Block Device: The block device for the first eMMC boot partition is usually something like
/dev/mmcblk0boot0. You can verify this by checking the available block devices on your system. -
Configure /etc/fw_env.config: Edit the file to include the correct block device, offset, and size. For example:
/dev/mmcblk0boot0 0x22000 0x2000- The offset (
0x22000) and size (0x2000) are typical values, but you should confirm these based on your specific setup and U-Boot configuration.
- The offset (
Verify the Configuration: After updating the configuration file, try running
fw_printenvagain. If the configuration is correct, it should display the current U-Boot environment variables. -
Set Environment Variables: Use
fw_setenvto set your desired environment variables. Remember that changes will only take effect after a reboot. -
Save Changes: If you make changes to the environment using the U-Boot console, use the
saveenvcommand to persist them.
By ensuring that /etc/fw_env.config is correctly configured, you should be able to use fw_printenv and fw_setenv without encountering initialization errors. If issues persist, double-check the block device and offset values, as these are critical for accessing the U-Boot environment correctly.
I hope this helps you get everything working smoothly. If you have any more questions, feel free to ask.
Toradex AI Assistant
