Trouble making static network configuration
I was follwing you web site, Networking with TorizonCore,
I don’t know how to get a command promp window locally after login with porttainer.io. So I do it through putty. The attached Word file shows the screenshot of the PuTTY window.
What should I do now?link text
It’s unclear, so you were or were not able to get a command prompt? The picture you attached has an image of Visual Studio not PuTTY.
Once you have a command prompt to the system you just need to run the commands in the article you linked. If these commands don’t work properly then please let me know.
