I had 1.5.203 this morning. Uninstalled everything and re-installed the early access extension which is now 1.5.205. I always get this error:
Running the commands you asked me to run in the beginning gave me this output:
This is on a fully updated Ubuntu 22.04 with VS Code 1.67.1
BTW. The link to libssl1.1l in the installation instructions should be http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1l-1ubuntu1.3_amd64.deb I think. The current link gives a 404. Running the install command however gave
I’m not sure if that went okay.
