Trouble copying device tree overlay
I am trying to scp my .dtbo file to the /boot/overlays/ directory however I am getting multiple issues. I am using MacOS, an Ubuntu VM, an Ixora & an Apalis imx8. I have set a static ip on the Mac(192.168.10.1) as well as an ip for the apalis module(192.168.10.2). I am able to successfully ping the carrier board from my Mac. I’ve tried to simply scp the file no flags in which I get a “scp: destination open “/boot/overlays/“: Failure “ error. If add the flag -O and or -r I get /boot/overlays/ is a directory error. If I specify the name of the file i’m copying “scp ubuntu-file-path apalis-file-path-filename” I get an error saying that the file name doesn’t exist on the Apalis. I have also tried sudo which doesn’t change anything.
Based on the error messages shown in your screenshots, the issue is that the /boot/overlays/ directory is read-only by default on Toradex modules. The scp command fails because it cannot write to this location without first remounting the partition as read-write.
Solution
Before copying your .dtbo file, you need to remount the boot partition as read-write on the Apalis iMX8. Here’s the correct procedure:
Step 1: Remount the Boot Partition as Read-Write
SSH into your Apalis iMX8 module and run:
mount -o remount,rw /boot
Step 2: Copy Your Device Tree Overlay
From your Mac or Ubuntu VM, use scp to copy the file. The correct syntax is:
scp /path/to/your/custom-overlay.dtbo torizon@192.168.10.2:/boot/overlays/
Note: Replace 192.168.10.2 with the actual IP address of your Apalis module (you mentioned setting it to 192.168.10.1, but your Mac also uses 192.168.10.1, which would cause a conflict—ensure they have different IPs).
Step 3: Enable the Overlay
After copying the .dtbo file to /boot/overlays/, you need to enable it by adding it to the overlays.txt file(1):
echo "fdt_overlays=custom-overlay.dtbo" >> /boot/overlays.txt
Or edit /boot/overlays.txt manually to add your overlay to the existing list.
Step 4: Sync and Reboot
Run the following commands on the Apalis module:
sync
reboot
Important: Do not power-cycle the board; use the reboot command to ensure filesystem changes are properly synced(1).
Additional Notes
  • The /boot partition is mounted read-only by default to protect critical boot files.
  • Always use sync before rebooting to ensure all changes are written to disk(2).
  • If you encounter permission issues, you may need to use sudo when remounting or editing files.
when doing
i get the error
mount: /boot: mount point not mounted or bad option.
This error indicates that the boot partition path differs on your system. Before I can provide the exact solution, I need to know which OS and version you’re running on your Apalis iMX8.
Could you please run the following command on your module and share the output?
tdx-info
This will help me determine the correct path to the overlays directory and the proper remount procedure for your specific configuration(1).
Alternatively, you can check which OS you’re running with:
cat /etc/os-release
The location of the overlays directory and the method to make it writable varies between:
  • Torizon OS (uses OSTree deployment structure)
  • Reference Images for Yocto Project (traditional /boot partition)
Once you confirm your OS and version, I can provide the exact commands for your setup.
boot to Qt for embedded Linux
version 4.0.23
Hi.
The scp commandline is invalid because of the “\” before
root@<ip-address>:/...
Therefore scp will could not interpret the command line correctly.
scp source-path/file user@dest-ip:/path/
Pleas try it w/o the backslash.
Regards
The issue was I needed space in between the backslash and root. If I remove the backslash entirely it fails. However it is now asking me for a password for root@192.168.10.2 which is my apalis. The password should be blank however when I empty a blank password it says permission denied. Even when I change the blank password on the apalis I get permission denied. Ive also tried changing the /boot permissions to 777
Also there isn’t an /boot/overlays directory on the apalis only .dtb files in the /boot/ directory. Do i put my file here? When creating the boot/overlay/ directory and trying to scp it times out. Same goes for when i try to copy the file to the /boot/directory.
Try the other way. Go to your imx8, login and copy the dtbo file from your host as sudo.
Furthermore, you should have a password even for sudo on your imx8.
I was able to copy my .dtbo file to /media/BOOT-mmcblk0p1/. I then edited the overlays.txt file to include my .dtbo file. I then rebooted the device and plugged in my display but I get a blank black screen with only the backlight on.
Do you get any error messages during boot?
And please do not include screenshots if not necessary, copy/paste your code by using </> in the tool menu above.
I do not see any errors during boot, everything checks out as [ OK ]. Okay I will use that tool.
Please show me the output from the debug-port over complete boot process (from power up to login).
 St[  OK  ] Removed slice Slice /system/modprobe.
[  OK  ] Stopped target Multi-User System.
[  OK  ] Stopped target Login Prompts.
[  OK  ] Stopped target Host and Network Name Lookups.
[  OK  ] Stopped target RPC Port Mapper.
[  OK  ] Stopped target Sound Card.
[  OK  ] Stopped target System Time Set.
[  OK  ] Stopped target Timer Units.
[  OK  ] Stopped Daily Cleanup of Temporary Directories.
[  OK  ] Stopped target Hardware activated USB gadget.
[  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Stopping Modem Manager...
         Stopping Save/Restore Sound Card State...
         Stopping Avahi mDNS/DNS-SD Stack...
         Stopping Kernel Logging Service...
         Stopping System Logging Service...
         Stopping Getty on tty1...
         Stopping Qt Debug Bridge Daemon...
         Stopping Serial Getty on ttyLP1...
         Stopping Load/Save Random Seed...
[  OK  ] Stopped Modem Manager.
[  OK  ] Stopped Kernel Logging Service.
[  OK  ] Stopped System Logging Service.
[  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
[  OK  ] Stopped Getty on tty1.
[  OK  ] Stopped Serial Getty on ttyLP1.
[  OK  ] Stopped Save/Restore Sound Card State.
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Stopped Session c1 of User root.
[  OK  ] Removed slice Slice /system/getty.
[  OK  ] Removed slice Slice /system/serial-getty.
         Stopping User Login Management...
         Stopping User Manager for UID 0...
[  OK  ] Stopped User Manager for UID 0.
         Stopping User Runtime Directory /run/user/0...
[  OK  ] Unmounted /run/user/0.
[  OK  ] Stopped User Runtime Directory /run/user/0.
[  OK  ] Removed slice User Slice of UID 0.
         Stopping Permit User Sessions...
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped target Network.
[  OK  ] Stopped target Remote File Systems.
         Stopping Connection service...
         Stopping Network Configuration...
         Stopping WPA supplicant...
[  OK  ] Stopped User Login Management.
[  OK  ] Stopped Network Configuration.
[  OK  ] Stopped WPA supplicant.
[  OK  ] Stopped Connection service.
[  OK  ] Stopped target Preparation for Network.
         Stopping D-Bus System Message Bus...
[  OK  ] Stopped IPv6 Packet Filtering Framework.
[  OK  ] Stopped IPv4 Packet Filtering Framework.
[  OK  ] Stopped D-Bus System Message Bus.
[  128.063744] ffs_data_put(): freeing
[  128.132095] unloading
[  OK  ] Stopped Qt Debug Bridge Daemon.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Path Units.
[  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
[  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
[  OK  ] Stopped target Slice Units.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Socket Units.
[  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Closed dropbear.socket.
[  OK  ] Closed Syslog Socket.
[  OK  ] Closed Network Service Netlink Socket.
[  OK  ] Closed Weston socket.
[  OK  ] Stopped target System Initialization.
         Stopping Hardware RNG Entropy Gatherer Daemon...
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Stopped Load Kernel Modules.
         Stopping Network Time Synchronization...
         Stopping Record System Boot/Shutdown in UTMP...
[  OK  ] Stopped Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Stopped Record System Boot/Shutdown in UTMP.
[  OK  ] Stopped Network Time Synchronization.
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped target Local File Systems.
         Unmounting /media/BOOT-mmcblk0p1...
         Unmounting /media/TORIZON OS-mmcblk1p1...
         Unmounting Temporary Directory /tmp...
         Unmounting /var/volatile...
[  OK  ] Unmounted /media/BOOT-mmcblk0p1.
[  OK  ] Unmounted /media/TORIZON OS-mmcblk1p1.
[  OK  ] Unmounted Temporary Directory /tmp.
[  OK  ] Unmounted /var/volatile.
[  OK  ] Stopped target Swaps.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped File System Check on /dev/mmcblk0p1.
[  OK  ] Stopped File System Check on /dev/mmcblk1p1.
[  OK  ] Removed slice Slice /system/systemd-fsck.
[  OK  ] Stopped target Preparation for Local File Systems.
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Stopped File System Check on Root Device.
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Reached target System Shutdown.
[  OK  ] Reached target Late Shutdown Services.
[  OK  ] Finished System Reboot.
[  OK  ] Reached target System Reboot.
[  133.090867] audit: type=1334 audit(1760424282.477:20): prog-id=10 op=UNLOAD
[  133.097939] audit: type=1334 audit(1760424282.477:21): prog-id=9 op=UNLOAD
[  133.104852] audit: type=1334 audit(1760424282.481:22): prog-id=6 op=UNLOAD
[  133.111970] audit: type=1334 audit(1760424282.481:23): prog-id=5 op=UNLOAD
[  133.118891] audit: type=1334 audit(1760424282.485:24): prog-id=12 op=UNLOAD
[  133.125883] audit: type=1334 audit(1760424282.485:25): prog-id=11 op=UNLOAD
[  133.132890] audit: type=1334 audit(1760424282.489:26): prog-id=8 op=UNLOAD
[  133.139796] audit: type=1334 audit(1760424282.489:27): prog-id=7 op=UNLOAD
[  133.146694] audit: type=1334 audit(1760424282.489:28): prog-id=4 op=UNLOAD
[  133.153594] audit: type=1334 audit(1760424282.489:29): prog-id=3 op=UNLOAD
[  133.163981] systemd-shutdown[1]: Using hardware watchdog 'i.MX SC watchdog t0
[  133.174543] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argt
[  133.192481] systemd-shutdown[1]: Syncing filesystems and block devices.
[  133.199313] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[  133.221063] systemd-journald[312]: Received SIGTERM from PID 1 (systemd-shut.
[  133.244659] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[  133.272205] systemd-shutdown[1]: Unmounting file systems.
[  133.279727] [963]: Remounting '/' read-only with options 'n/a'.
[  133.296479] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[  133.311689] systemd-shutdown[1]: All filesystems unmounted.
[  133.317575] systemd-shutdown[1]: Deactivating swaps.
[  133.322694] systemd-shutdown[1]: All swaps deactivated.
[  133.328207] systemd-shutdown[1]: Detaching loop devices.
[  133.335600] systemd-shutdown[1]: All loop devices detached.
[  133.341311] systemd-shutdown[1]: Stopping MD devices.
[  133.346537] systemd-shutdown[1]: All MD devices stopped.
[  133.351863] systemd-shutdown[1]: Detaching DM devices.
[  133.357134] systemd-shutdown[1]: All DM devices detached.
[  133.362556] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD de.
[  133.380612] systemd-shutdown[1]: Syncing filesystems and block devices.
[  133.387353] systemd-shutdown[1]: Rebooting.
[  133.391560] kvm: exiting hardware virtualization
[  133.448808] mwifiex_pcie 0000:01:00.0: info: shutdown mwifiex...
[  133.454917] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[  133.490456] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[  133.554581] mwifiex_pcie 0000:01:00.0: performing cancel_work_sync()...
[  133.561214] mwifiex_pcie 0000:01:00.0: cancel_work_sync() done
[  133.580103] ci_hdrc ci_hdrc.1: remove, state 4
[  133.584582] usb usb4: USB disconnect, device number 1
[  133.590214] ci_hdrc ci_hdrc.1: USB bus 4 deregistered
[  133.595570] ci_hdrc ci_hdrc.0: remove, state 4
[  133.600032] usb usb3: USB disconnect, device number 1
[  133.605385] ci_hdrc ci_hdrc.0: USB bus 3 deregistered
[  133.758325] arm-smmu 51400000.iommu: disabling translation
[  133.765044] reboot: Restarting system
U-Boot 2022.04-0+git.7588eb559ca2 (May 28 2024 - 11:19:14 +0000)
CPU:   NXP i.MX8QM RevB A53 at 1200 MHz at 35C
DRAM:  4 GiB
Core:  194 devices, 20 uclasses, devicetree: separate
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
In:    serial
Out:   serial
Err:   serial
Model: Toradex 0037 Apalis iMX8QM 4GB WB IT V1.1C
Serial#: 07039747
 BuildInfo:
  - SCFW 6638c032, SECO-FW c9de51c0, IMX-MKIMAGE 3bfcfccb, ATF 3c1583b
  - U-Boot 2022.04-0+git.7588eb559ca2
flash target is MMC:0
Net:   eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
MMC: no card present
Scanning mmc 0:1...
Found U-Boot script /boot.scr
6010 bytes read in 7 ms (837.9 KiB/s)
## Executing script at 9d480000
Loading DeviceTree: imx8qm-apalis-v1.1-eval.dtb
170019 bytes read in 11 ms (14.7 MiB/s)
138 bytes read in 5 ms (26.4 KiB/s)
Applying Overlay: apalis-imx8_hdmi_overlay.dtbo
2205 bytes read in 4 ms (538.1 KiB/s)
Applying Overlay: apalis-imx8_spi1_spidev_overlay.dtbo
551 bytes read in 3 ms (178.7 KiB/s)
Applying Overlay: apalis-imx8_spi2_spidev_overlay.dtbo
Applying Overlay: apalis-imx8_koe.dtbo
Failed to load 'overlays/apalis-imx8_koe.dtbo'
11648655 bytes read in 267 ms (41.6 MiB/s)
Bootargs: root=PARTUUID=2e15f42e-02 ro rootwait console=tty1 console=ttyLP1,115n
   Uncompressing Kernel Image
## Flattened Device Tree blob at 9d400000
   Booting using the fdt blob at 0x9d400000
   Loading Device Tree to 00000000fd626000, end 00000000fd672fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.15.148-0+git.bfdbfb2c85fb (oe-user@oe-host) (aar4
[    0.000000] Machine model: Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Bd
[    0.000000] efi: UEFI not found.
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'm4@B
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, B
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id sharl
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000090400000, B
[    0.000000] OF: reserved mem: initialized node vdevbuffer@90400000, compatibl
[    0.000000] earlycon: lpuart32 at MMIO32 0x000000005a070000 (options '')
[    0.000000] printk: bootconsole [lpuart32] enabled
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080200000-0x00000008fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x8ff777800-0x8ff779fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080200000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080200000-0x0000000083ffffff]
[    0.000000]   node   0: [mem 0x0000000084000000-0x00000000863fffff]
[    0.000000]   node   0: [mem 0x0000000086400000-0x00000000901fffff]
[    0.000000]   node   0: [mem 0x0000000090200000-0x00000000904fffff]
[    0.000000]   node   0: [mem 0x0000000090500000-0x0000000091ffffff]
[    0.000000]   node   0: [mem 0x0000000092000000-0x00000000921fffff]
[    0.000000]   node   0: [mem 0x0000000092200000-0x00000000923fffff]
[    0.000000]   node   0: [mem 0x0000000092400000-0x00000000951fffff]
[    0.000000]   node   0: [mem 0x0000000095200000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x00000008ffffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 20 pages/cpu s42712 r8192 d31016 u81920
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1031688
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=PARTUUID=2e15f42e-02 ro rootwait conson
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 byte)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes,)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000bc000000-0x00000000c00000)
[    0.000000] Memory: 2812628K/4192256K available (16448K kernel code, 1760K r)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 ji.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 512 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000051b00000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[    0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199s
[    0.008826] Console: colour dummy device 80x25
[    0.013427] printk: console [tty1] enabled
[    0.017266] Calibrating delay loop (skipped), value calculated using timer f)
[    0.027447] pid_max: default: 32768 minimum: 301
[    0.032098] LSM: Security Framework initializing
[    0.036756] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, lin)
[    0.044052] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.053592] rcu: Hierarchical SRCU implementation.
[    0.059553] EFI services will not be available.
[    0.064033] smp: Bringing up secondary CPUs ...
[    0.069079] Detected VIPT I-cache on CPU1
[    0.069120] GICv3: CPU1: found redistributor 1 region 0:0x0000000051b20000
[    0.069173] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.069985] Detected VIPT I-cache on CPU2
[    0.070006] GICv3: CPU2: found redistributor 2 region 0:0x0000000051b40000
[    0.070029] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.070779] Detected VIPT I-cache on CPU3
[    0.070798] GICv3: CPU3: found redistributor 3 region 0:0x0000000051b60000
[    0.070820] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.072437] CPU features: detected: Spectre-v2
[    0.072444] CPU features: detected: Spectre-v3a
[    0.072448] CPU features: detected: Spectre-BHB
[    0.072454] CPU features: detected: ARM erratum 1742098
[    0.072457] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.072459] Detected PIPT I-cache on CPU4
[    0.072480] GICv3: CPU4: found redistributor 100 region 0:0x0000000051b80000
[    0.072504] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.073270] Detected PIPT I-cache on CPU5
[    0.073285] GICv3: CPU5: found redistributor 101 region 0:0x0000000051ba0000
[    0.073301] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.073365] smp: Brought up 1 node, 6 CPUs
[    0.189992] SMP: Total of 6 processors activated.
[    0.194673] CPU features: detected: 32-bit EL0 Support
[    0.199804] CPU features: detected: 32-bit EL1 Support
[    0.204920] CPU features: detected: CRC32 instructions
[    0.223150] CPU: All CPU(s) started at EL2
[    0.226942] alternatives: patching kernel code
[    0.233041] devtmpfs: initialized
[    0.253735] KASLR disabled due to lack of seed
[    0.258027] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    0.267600] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.304520] pinctrl core: initialized pinctrl subsystem
[    0.310113] DMI not present or invalid.
[    0.314208] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.324494] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.331597] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic alls
[    0.339412] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic as
[    0.347088] audit: initializing netlink subsys (disabled)
[    0.352542] audit: type=2000 audit(0.256:1): state=initialized audit_enabled1
[    0.353079] thermal_sys: Registered thermal governor 'step_wise'
[    0.360121] thermal_sys: Registered thermal governor 'power_allocator'
[    0.366778] cpuidle: using governor menu
[    0.377119] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.383777] ASID allocator initialised with 65536 entries
[    0.389313] Serial: AMBA PL011 UART driver
[    0.393178] imx mu driver is registered.
[    0.397044] imx rpmsg driver is registered.
[    0.460270] platform 56268000.hdmi: Fixing up cyclic dependency with 5618000u
[    0.480653] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.487053] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.493720] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.500413] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.508339] cryptd: max_cpu_qlen set to 1000
[    0.516423] ACPI: Interpreter disabled.
[    0.522580] iommu: Default domain type: Translated
[    0.527131] iommu: DMA domain TLB invalidation policy: strict mode
[    0.533568] vgaarb: loaded
[    0.536364] SCSI subsystem initialized
[    0.540132] usbcore: registered new interface driver usbfs
[    0.545321] usbcore: registered new interface driver hub
[    0.550610] usbcore: registered new device driver usb
[    0.557649] mc: Linux media interface: v0.10
[    0.561606] videodev: Linux video capture interface: v2.00
[    0.567118] pps_core: LinuxPPS API ver. 1 registered
[    0.572008] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    0.581148] PTP clock support registered
[    0.585367] EDAC MC: Ver: 3.0.0
[    0.589736] FPGA manager framework
[    0.592870] Advanced Linux Sound Architecture Driver Initialized.
[    0.600171] imx-scu scu: NXP i.MX SCU Initialized
[    0.631577] imx8qm-pinctrl scu:pinctrl: initialized IMX pinctrl driver
[    0.642396] clocksource: Switched to clocksource arch_sys_counter
[    0.648361] VFS: Disk quotas dquot_6.6.0
[    0.652122] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.659131] pnp: PnP ACPI: disabled
[    0.696037] NET: Registered PF_INET protocol family
[    0.700829] IP idents hash table entries: 65536 (order: 7, 524288 bytes, lin)
[    0.709642] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 327)
[    0.717912] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes,)
[    0.725582] TCP established hash table entries: 32768 (order: 6, 262144 byte)
[    0.733709] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, line)
[    0.741298] TCP: Hash tables configured (established 32768 bind 32768)
[    0.747589] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.754251] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.761463] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.767319] RPC: Registered named UNIX socket transport module.
[    0.772916] RPC: Registered udp transport module.
[    0.777620] RPC: Registered tcp transport module.
[    0.782290] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.788728] PCI: CLS 0 bytes, default 64
[    0.793361] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ae
[    0.802791] kvm [1]: IPA Size Limit: 40 bits
[    0.807764] kvm [1]: vgic-v2@52020000
[    0.811109] kvm [1]: GIC system register CPU interface enabled
[    0.817029] kvm [1]: vgic interrupt IRQ9
[    0.820987] kvm [1]: Hyp mode initialized successfully
[    0.829833] Initialise system trusted keyrings
[    0.834068] workingset: timestamp_bits=42 max_order=20 bucket_order=0
[    0.845497] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.851499] NFS: Registering the id_resolver key type
[    0.856244] Key type id_resolver registered
[    0.860387] Key type id_legacy registered
[    0.864444] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.871071] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registerin.
[    0.878596] 9p: Installing v9fs 9p2000 file system support
[    0.919423] Key type asymmetric registered
[    0.923188] Asymmetric key parser 'x509' registered
[    0.928154] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    0.935444] io scheduler mq-deadline registered
[    0.939952] io scheduler kyber registered
[    0.960098] EINJ: ACPI disabled.
[    1.187407] mxs-dma 5b810000.dma-apbh: initialized
[    1.194948] Bus freq driver module loaded
[    1.207366] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.217790] 5a060000.serial: ttyLP0 at MMIO 0x5a060010 (irq = 59, base_baud T
[    1.227587] 5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 60, base_baud d
[    1.236746] printk: console [ttyLP1] enabled
[    1.245179] printk: bootconsole [lpuart32] disabled
[    1.255503] 5a080000.serial: ttyLP2 at MMIO 0x5a080010 (irq = 61, base_baud T
[    1.265596] 5a090000.serial: ttyLP3 at MMIO 0x5a090010 (irq = 62, base_baud T
[    1.277413] arm-smmu 51400000.iommu: probing hardware configuration...
[    1.283978] arm-smmu 51400000.iommu: SMMUv2 with:
[    1.288698] arm-smmu 51400000.iommu:         stage 1 translation
[    1.294114] arm-smmu 51400000.iommu:         stage 2 translation
[    1.299533] arm-smmu 51400000.iommu:         nested translation
[    1.304859] arm-smmu 51400000.iommu:         stream matching with 32 registes
[    1.312008] arm-smmu 51400000.iommu:         32 context banks (0 stage-2 onl)
[    1.318641] arm-smmu 51400000.iommu:         Supported page sizes: 0x61311000
[    1.325184] arm-smmu 51400000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    1.331726] arm-smmu 51400000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    1.338352] arm-smmu 51400000.iommu:         preserved 0 boot mappings
[    1.438358] brd: module loaded
[    1.446441] loop: module loaded
[    1.452821] megasas: 07.717.02.00-rc1
[    1.466573] tun: Universal TUN/TAP device driver, 1.6
[    1.473552] fec 5b040000.ethernet: Adding to iommu group 0
[    1.479833] pps pps0: new PPS source ptp0
[    1.489896] e1000: Intel(R) PRO/1000 Network Driver
[    1.494811] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.500612] e1000e: Intel(R) PRO/1000 Network Driver
[    1.505590] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.511571] igb: Intel(R) Gigabit Ethernet Network Driver
[    1.516993] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.522607] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.528891] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.535345] usbcore: registered new device driver r8152-cfgselector
[    1.541680] usbcore: registered new interface driver r8152
[    1.547405] VFIO - User Level meta-driver version: 0.3
[    1.557414] cdns3-imx 5b110000.usb: Adding to iommu group 1
[    1.565382] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.571970] ehci-pci: EHCI PCI platform driver
[    1.576491] ehci-platform: EHCI generic platform driver
[    1.582442] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.588642] ohci-pci: OHCI PCI platform driver
[    1.593143] ohci-platform: OHCI generic platform driver
[    1.600098] usbcore: registered new interface driver uas
[    1.605473] usbcore: registered new interface driver usb-storage
[    1.611552] usbcore: registered new interface driver usbserial_generic
[    1.618107] usbserial: USB Serial support registered for generic
[    1.624222] usbcore: registered new interface driver ftdi_sio
[    1.630008] usbserial: USB Serial support registered for FTDI USB Serial Deve
[    1.637367] usbcore: registered new interface driver usb_serial_simple
[    1.643928] usbserial: USB Serial support registered for carelink
[    1.650051] usbserial: USB Serial support registered for flashloader
[    1.656569] usbserial: USB Serial support registered for funsoft
[    1.662699] usbserial: USB Serial support registered for google
[    1.668680] usbserial: USB Serial support registered for hp4x
[    1.674459] usbserial: USB Serial support registered for kaufmann
[    1.680592] usbserial: USB Serial support registered for libtransistor
[    1.687160] usbserial: USB Serial support registered for moto_modem
[    1.693479] usbserial: USB Serial support registered for motorola_tetra
[    1.700138] usbserial: USB Serial support registered for nokia
[    1.706003] usbserial: USB Serial support .712397] usbserial: USB Serial supi
[    1.718790] usbserial: USB Serial support registered for suunto
[    1.724755] usbserial: USB Serial support registered for vivopay
[    1.730801] usbserial: USB Serial support registered for zio
[    1.736569] usbcore: registered new interface driver usb_ehset_test
[    1.744614] usbcore: registered new device driver onboard-usb-hub
[    1.760263] input: sc-powerkey as /devices/platform/sc-powerkey/input/input0
[    1.769866] imx-sc-rtc scu:rtc: registered as rtc1
[    1.775505] i2c_dev: i2c /dev entries driver
[    1.790569] amphion-vpu-core 2d080000.vpu-core: [0] = decoder
[    1.798541] amphion-vpu-core 2d090000.vpu-core: [1] = encoder
[    1.806513] amphion-vpu-core 2d0a0000.vpu-core: [2] = encoder
[    1.826721] sdhci: Secure Digital Host Controller Interface driver
[    1.832946] sdhci: Copyright(c) Pierre Ossman
[    1.838594] Synopsys Designware Multimedia Card Interface Driver
[    1.846289] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.854264] sdhci-esdhc-imx 5b010000.mmc: Adding to iommu group 2
[    1.860487] ledtrig-cpu: registered to indicate activity on CPUs
[    1.868914] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.875868] usbcore: registered new interface driver usbhid
[    1.881710] usbhid: USB HID core driver
[    1.898466] mmc0: SDHCI controller on 5b010000.mmc [5b010000.mmc] using ADMA
[    1.899151]  cs_system_cfg: CoreSight Configuration manager initialised
[    1.922165] NET: Registered PF_LLC protocol family
[    1.927520] NET: Registered PF_INET6 protocol family
[    1.933286] Segment Routing with IPv6
[    1.936979] In-situ OAM (IOAM) with IPv6
[    1.940970] NET: Registered PF_PACKET protocol family
[    1.946201] 8021q: 802.1Q VLAN Support v1.8
[    1.950490] 9pnet: Installing 9P2000 support
[    1.954854] tsn generic netlink module v1 init...
[    1.959642] Key type dns_resolver registered
[    1.964328] Loading compiled-in X.509 certificates
[    2.001831] mmc0: new HS400 MMC card at address 0001
[    2.006100] gpio-414 (CONNECTOR_IS_HDMI): hogged as output/high
[    2.007628] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    2.019297] imx-lpi2c 5a800000.i2c: can't get pinctrl, bus recovery not suppd
[    2.019357]  mmcblk0: p1 p2
[    2.026820] imx-lpi2c 5a800000.i2c: use pio mode
[    2.030123] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[    2.034396] i2c i2c-2: LPI2C adapter registered
[    2.040379] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[    2.044213] imx-lpi2c 5a810000.i2c: use pio mode
[    2.049760] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (234:0)
[    2.062841] sgtl5000 3-000a: sgtl5000 revision 0x11
[    2.109094] usb3503 3-0008: SP_ILOCK failed (-5)
[    2.113760] usb3503 3-0008: usb3503_probe: probed in hub mode
[    2.119847] i2c i2c-3: LPI2C adapter registered
[    2.125500] imx-lpi2c 5a820000.i2c: use pio mode
[    2.132641] rtc-ds1307 4-0068: oscillator failed, set time!
[    2.138356] rtc-ds1307 4-0068: registered as rtc0
[    2.144284] rtc-ds1307 4-0068: hctosys: unable to read the hardware clock
[    2.151136] i2c i2c-4: LPI2C adapter registered
[    2.156447] imx-lpi2c 5a830000.i2c: use pio mode
[    2.161259] i2c i2c-5: LPI2C adapter registered
[    2.185210] dpu-core 56180000.dpu: driver probed
[    2.192806] dpu-core 57180000.dpu: driver probed
[    2.202965] pps pps0: new PPS source ptp0
[    2.210984] fec 5b040000.ethernet eth0: registered PHC device 0
[    2.217823] cdns-usb3 5b130000.usb: Adding to iommu group 1
[    2.224150] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.229721] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus n1
[    2.237917] xhci-hcd xhci-hcd.1.auto: hcc params 0x200073c8 hci version 0x100
[    2.247343] xhci-hcd xhci-hcd.1.auto: irq 245, io mem 0x5b130000
[    2.253533] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.259106] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus n2
[    2.266857] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    2.273956] hub 1-0:1.0: USB hub found
[    2.277739] hub 1-0:1.0: 1 port detected
[    2.281948] usb usb2: We don't know the algorithms for LPM for this host, di.
[    2.290452] hub 2-0:1.0: USB hub found
[    2.294225] hub 2-0:1.0: 1 port detected
[    2.302724] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    2.307635] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 3
[    2.330413] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    2.336641] hub 3-0:1.0: USB hub found
[    2.340687] hub 3-0:1.0: 1 port detected
[    2.349351] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    2.354268] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 4
[    2.374410] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    2.380788] hub 4-0:1.0: USB hub found
[    2.384802] hub 4-0:1.0: 1 port detected
[    2.390487] gpio-fan gpio-fan: GPIO fan initialized
[    2.399240] sdhci-esdhc-imx 5b020000.mmc: Adding to iommu group 2
[    2.400149] sdhci-esdhc-imx 5b030000.mmc: Adding to iommu group 2
[    2.403563] imx6q-pcie 5f010000.pcie: supply epdev_on not found, using dummyr
[    2.403603] imx6q-pcie 5f000000.pcie: supply epdev_on not found, using dummyr
[    2.404040] imx6q-pcie 5f000000.pcie: No cache used with register defaults s!
[    2.404046] imx6q-pcie 5f010000.pcie: pcie 5f010000.pcie: PCIe PLL is locked.
[    2.406129] sdhci-esdhc-imx 5b020000.mmc: Got CD GPIO
[    2.406339] debugfs: Directory 'lvds1' with parent 'pm_genpd' already presen!
[    2.406472] debugfs: Directory 'mipi1-i2c1' with parent 'pm_genpd' already p!
[    2.406480] debugfs: Directory 'mipi1-i2c0' with parent 'pm_genpd' already p!
[    2.406487] debugfs: Directory 'mipi1-pwm0' with parelready present!
[    2.406493] debugfs: Directory 'mipi1' with parent 'pm_genpd' already presen!
[    2.411950] sdhci-esdhc-imx 5b030000.mmc: Got CD GPIO
[    2.423355] ALSA device list:
[    2.446099] mmc1: SDHCI controller on 5b020000.mmc [5b020000.mmc] using ADMA
[    2.447477]   No soundcards found.
[    2.458637] mmc2: SDHCI controller on 5b030000.mmc [5b030000.mmc] using ADMA
[    2.488662] mmc1: host does not support reading read-only switch, assuming we
[    2.515760] imx6q-pcie 5f000000.pcie: PCIe PLL is locked.
[    2.529355] mmc1: new high speed SDHC card at address aaaa
[    2.535743] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[    2.545263]  mmcblk1: p1
[    2.634594] imx6q-pcie 5f010000.pcie: iATU unroll: disabled
[    2.640223] imx6q-pcie 5f010000.pcie: Detected iATU regions: 6 outbound, 6 id
[    2.647849] usb 4-1: new high-speed USB device number 2 using ci_hdrc
[    2.654400] imx6q-pcie 5f010000.pcie: host bridge /bus@5f000000/pcie@0x5f010:
[    2.662461] imx6q-pcie 5f010000.pcie:       IO 0x007ff80000..0x007ff8ffff ->0
[    2.670667] imx6q-pcie 5f010000.pcie:      MEM 0x0070000000..0x007fefffff ->0
[    2.678956] imx6q-pcie 5f010000.pcie: iATU unroll: disabled
[    2.684543] imx6q-pcie 5f010000.pcie: Detected iATU regions: 6 outbound, 6 id
[    2.742558] imx6q-pcie 5f000000.pcie: iATU unroll: disabled
[    2.748199] imx6q-pcie 5f000000.pcie: Detected iATU regions: 6 outbound, 6 id
[    2.756030] imx6q-pcie 5f000000.pcie: host bridge /bus@5f000000/pcie@0x5f000:
[    2.764323] imx6q-pcie 5f000000.pcie:       IO 0x006ff80000..0x006ff8ffff ->0
[    2.772533] imx6q-pcie 5f000000.pcie:      MEM 0x0060000000..0x006fefffff ->0
[    2.780847] imx6q-pcie 5f000000.pcie: iATU unroll: disabled
[    2.786437] imx6q-pcie 5f000000.pcie: Detected iATU regions: 6 outbound, 6 id
[    2.792183] imx6q-pcie 5f010000.pcie: Link up
[    2.794419] usb 4-1: device no response, device descriptor read/64, error -71
[    2.798410] imx6q-pcie 5f010000.pcie: Link: Gen2 disabled
[    2.811240] imx6q-pcie 5f010000.pcie: Link up, Gen1
[    2.922431] imx6q-pcie 5f010000.pcie: Link up
[    2.927016] imx6q-pcie 5f010000.pcie: PCI host bridge to bus 0000:00
[    2.933661] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.939168] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.945369] pci_bus 0000:00: root bus resource [mem 0x70000000-0x7fefffff]
[    2.952277] pci 0000:00:00.0: [1957:0000] type 01 class 0x060400
[    2.958309] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00ffffff]
[    2.964592] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x00ffffff pref]
[    2.971345] pci 0000:00:00.0: supports D1 D2
[    2.975623] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[    2.984714] pci 0000:01:00.0: [1b4b:2b42] type 00 class 0x020000
[    2.990795] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pre]
[    2.998124] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x000fffff 64bit pre]
[    3.005673] pci 0000:01:00.0: supports D1 D2
[    3.009958] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[    3.016444] pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited b)
[    3.049618] pci 0000:00:00.0: BAR 0: assigned [mem 0x70000000-0x70ffffff]
[    3.054440] usb 4-1: device no response, device descriptor read/64, error -71
[    3.056452] pci 0000:00:00.0: BAR 6: assigned [mem 0x71000000-0x71ffffff pre]
[    3.070836] pci 0000:00:00.0: BAR 15: assigned [mem 0x72000000-0x721fffff 64]
[    3.078678] pci 0000:01:00.0: BAR 0: assigned [mem 0x72000000-0x720fffff 64b]
[    3.086471] pci 0000:01:00.0: BAR 2: assigned [mem 0x72100000-0x721fffff 64b]
[    3.094251] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    3.099494] pci 0000:00:00.0:   bridge window [mem 0x72000000-0x721fffff 64b]
[    3.107525] pcieport 0000:00:00.0: PME: Signaling with IRQ 573
[    3.298420] usb 4-1: new high-speed USB device number 3 using ci_hdrc
[    3.442433] usb 4-1: device no response, device descriptor read/64, error -71
[    3.694428] usb 4-1: device no response, device descriptor read/64, error -71
[    3.794558] imx6q-pcie 5f000000.pcie: Phy link never came up
[    3.800350] regulator-dummy: Underflow of regulator enable count
[    3.806438] usb usb4-port1: attempt power cycle
[    3.807112] imx6q-pcie: probe of 5f000000.pcie failed with error -110
[    3.825070] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. .
[    3.834917] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    3.844576] devtmpfs: mounted
[    3.848926] Freeing unused kernel memory: 3264K
[    3.862516] Run /sbin/init as init process
[    3.966506] systemd[1]: System time before build time, advancing clock.
[    4.000533] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -)
[    4.032521] systemd[1]: Detected architecture arm64.
[    4.050423] random: crng init done
Welcome to Boot to Qt for Embedded Linux 4.0.23 (kirkstone)!
[    4.091249] systemd[1]: Hostname set to <b2qt-apalis-imx8>.
[    4.226414] usb 4-1: new high-speed USB device number 4 using ci_hdrc
[    4.418006] systemd[1]: Queued start job for default target Multi-User Syste.
[    4.509115] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    4.533579] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    4.557264] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    4.581031] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    4.602924] systemd[1]: Started Dispatch Password Requests to Console Direct.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    4.626810] systemd[1]: Started Forward Password Requests to Wall Directory .
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    4.650894] systemd[1]: Reached target Host and Network Name Lookups.
[    4.654431] usb 4-1: device not accepting address 4, error -71
[  OK  ] Reached target Host and Network Name Lookups.
[    4.678553] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    4.698617] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    4.718775] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    4.738534] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    4.781291] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activati[    4.790416] usb 4-1: new high-sc
on Socket.
[    4.814883] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    4.835643] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    4.854744] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    4.879739] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    4.903250] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    4.927438] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    4.947163] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    4.971527] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    4.995207] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    5.019239] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    5.048694] systemd[1]: Mounting Huge Pages File System...
[    5.074946] systemd[1]: Mounting POSIX Message Queue File System...
[    5.103064] systemd[1]: Mounting Kernel Debug File System...
[    5.123056] systemd[1]: Kernel Trace File System was skipped because of a fa.
[    5.142240] systemd[1]: Mounting Temporary Directory /tmp...
[    5.170946] systemd[1]: Starting Create List of Static Device Nodes...
[    5.199415] systemd[1]: Starting Load Kernel Module configfs...
[    5.222421] usb 4-1: device not accepting address 5, error -71
[    5.228330] usb usb4-port1: unable to enumerate USB device
[    5.229203] systemd[1]: Starting Load Kernel Module drm...
[    5.261284] systemd[1]: Starting Load Kernel Module fuse...
[    5.280488] fuse: init (API version 7.34)
[    5.290251] systemd[1]: Starting RPC Bind...
[    5.319390] systemd[1]: Starting File System Check on Root Device...
[    5.349199] systemd[1]: Starting Journal Service...
[    5.361045] systemd[1]: Starting Load Kernel Modules...
[    5.371108] systemd[1]: Starting Generate network units from Kernel command .
         Starting Generate network …ts from Kernel com[    5.381414] galcore: l.
mand line...
[    5.383999] systemd[1]: Starting Coldplug All udev Devices...
         Starting Coldplug All udev Devices...[    5.405634] Galcore version 6.1
[    5.432084] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    5.455123] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted Huge Pages File System.
[    5.479090] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    5.503066] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    5.522983] systemd[1]: Mounted Temporary Directory /tmp.
[  OK  ] Mounted Temporary Directory /tmp.
[    5.547388] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.[    5.552738] [drm] Initialized vivante 1.0.00
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[  OK  ] Finished File System Check on Root Device.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Remount Root and Kernel File Systems...
[    5.794534] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
         Starting Apply Kernel Variables...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Remount Root and Kernel File Systems.
[  OK  ] Finished Apply Kernel Variables.
         Starting Flush Journal to Persistent Storage...
[    5.928843] systemd-journald[310]: Received client request to flush runtime .
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /var/volatile...
[    6.047895] audit: type=1334 audit(1651167747.080:2): prog-id=5 op=LOAD
[    6.054893] audit: type=1334 audit(1651167747.088:3): prog-id=6 op=LOAD
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Finished Create Volatile Files and Directories.
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Started Rule-based Manager for Device Events and Files.
         Starting Network Time Synchronization...
         Starting Wait for udev To …plete Device Initialization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[    6.535592] systemd-journald[310]: Oldest entry in /run/log/journal/5031de8c.
[  OK  ] Started Network Time Synchronization[    6.558499] systemd-journald[31.
[  OK  ] Reached target System Time Set.
[    6.606845] amphion-vpu-core 2d080000.vpu-core: decoder firmware version : 15
[    6.624385] amphion-vpu-core 2d090000.vpu-core: encoder firmware version : 13
[    6.707960] caam 31400000.crypto: device ID = 0x0a16040000000100 (Era 9)
[    6.714778] caam 31400000.crypto: job rings = 2, qi = 0
[    6.725411] imx8_media_dev: module is from the staging directory, the qualit.
[    6.747013] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_)
[    6.816512] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_)
[    6.825416] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_op)
[    6.854070] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_op)
[    6.879006] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_op)
[    6.901609] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_op)
[    6.928267] CAN device driver interface
[  OK  ] Reached target Hardware activated USB gadget.
[    7.093683] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/vid)
[    7.163825] [drm] Started firmware!
[    7.183900] [drm] HDP FW Version - ver 34559 verlib 20560
[    7.198933] ahci-imx 5f020000.sata: Adding to iommu group 3
[    7.198944] cdns-mhdp-imx 56268000.hdmi: lane-mapping 0x93
[    7.210148] [drm] HDCP is disabled
[    7.211570] ahci-imx 5f020000.sata: phy impedance ratio is not specified.
[    7.220512] ahci-imx 5f020000.sata: No cache used with register defaults set!
[    7.228291] ahci-imx 5f020000.sata: supply ahci not found, using dummy regulr
[    7.257022] ahci-imx 5f020000.sata: supply phy not found, using dummy regular
[    7.261989] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/vid)
[    7.262689] imx-drm display-subsystem: bound 56268000.hdmi (ops cdns_mhdp_im)
[    7.263355] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem o1
[    7.264526] imx-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    7.264902] ahci-imx 5f020000.sata: supply target not found, using dummy regr
[    7.265126] ahci-imx 5f020000.sata: external osc is used.
[    7.267974] ahci-imx 5f020000.sata: no ahb clock.
[    7.268082] ahci-imx 5f020000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0e
[    7.268096] ahci-imx 5f020000.sata: flags: 64bit ncq sntf pm clo only pmp fb
[    7.309476] scsi host0: ahci-imx
[    7.337134] ata1: SATA max UDMA/133 mmio [mem 0x5f020000-0x5f02ffff] port 0x3
[    7.349185] imx ahci driver is registered.
[    7.361582] cfg80211: Loading compiled-in X.509 certificates for regulatory e
[    7.370364] debugfs: File 'Capture' in directory 'dapm' already present!
[    7.389259] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.396907] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7'
[    7.397671] input: imx-audio-hdmi-tx HDMI Jack as /devices/platform/sound-hd1
[    7.662218] ata1: SATA link down (SStatus 0 SControl 300)
[    7.691019] mwifiex_pcie 0000:01:00.0: no quirks enabled
[    7.697556] mwifiex_pcie 0000:01:00.0: enabling device (0000 -> 0002)
[    7.704302] mwifiex_pcie: PCI memory map Virt0: 000000009a73d1f4 PCI memory 1
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.9 | VT102 | Offline | ttyUSB0
You see a few lines above “Starting the kernel…”
You overlay file must be located in the overlays directory.
Okay great I am now getting some color to the display however this is what I get. Not sure if it’s a termination issue. The display works fine when using an external controller board and hdmi.
I assume, you have checked the hardware connection between the display and the imx8 carrier board.
What about the display timing parameters in your overlay? Is the overlay provided by the display manufacturer or is the timing defined by you?
I have seen, you have activated both, the HDMI and LVDS display hardware in your post Trouble copying device tree overlay - #9 by Waunye11.
Try to remove the HDMI overlay in your overlays.txt and check if this was the reason.
Unfortunately I think I just fried the lvds interface while seating the cable. The device rebooted and now there is no color displaying. Will likely need to replace the board.
Oh no…, ok. Please let me know if it works when you replaced the board.
