Is there any problem in repo?
I am following these steps just as usual to build yocto image for tk1 module
angstrom-lxde-image
https://developer.toradex.com/knowledge-base/board-support-package/openembedded-core#tab-28
BSP 2.8 tab
when i run
repo sync
command , i get this trace back error
Fetching projects: 100% (17/17), done.
fatal: failed to unpack tree object HEAD
error: Cannot checkout meta-qt4: GitError: Cannot initialize work tree for meta-qt4
File “/home/ugv/oe-core_lxde/.repo/repo/main.py”, line 541, in
_Main(sys.argv[1:])
File “/home/ugv/oe-core_lxde/.repo/repo/main.py”, line 516, in _Main
result = run()
File “/home/ugv/oe-core_lxde/.repo/repo/main.py”, line 509, in
run = lambda: repo._Run(name, gopts, argv) or 0
File “/home/ugv/oe-core_lxde/.repo/repo/main.py”, line 212, in _Run
result = cmd.Execute(copts, cargs)
File “/home/ugv/oe-core_lxde/.repo/repo/subcmds/sync.py”, line 994, in Execute
self._Checkout(all_projects, opt)
File “/home/ugv/oe-core_lxde/.repo/repo/subcmds/sync.py”, line 553, in _Checkout
self._CheckoutWorker(**kwargs)
File “/home/ugv/oe-core_lxde/.repo/repo/subcmds/sync.py”, line 435, in _CheckoutWorker
return self._CheckoutOne(opt, project, args, *kwargs)
File “/home/ugv/oe-core_lxde/.repo/repo/subcmds/sync.py”, line 469, in _CheckoutOne
project.Sync_LocalHalf(syncbuf, force_sync=opt.force_sync)
File “/home/ugv/oe-core_lxde/.repo/repo/project.py”, line 1532, in Sync_LocalHalf
self._InitWorkTree(force_sync=force_sync, submodules=submodules)
File “/home/ugv/oe-core_lxde/.repo/repo/project.py”, line 2784, in _InitWorkTree
raise GitError('Cannot initialize work tree for ’ + self.name)
error.GitError: Cannot initialize work tree for meta-qt4
