@henrique.tx I attached the files requested
imx6ull-colibri-emmc-iris-v2.dtd.txt (63.4 KB)
imx6ull-colibri-iris-v2.dtsi (2.9 KB)
Infineon-Iridium_1-0_9670_HD-AdditionalTechnicalInformation-v01_01-EN.pdf (763.3 KB)
I am using the same Colibri IMx6ull emmc and slb9670 I am facing same issue my TPM driver is not getting loaded, Can you please help me with changes you have done to run it.
Hi @fxtsupport, Hi @ashutosh.lahoti ,
I just took this over here. I will investigate what is happening here and let you guys know as soon as I have some new information.
Kevin
Hi @fxtsupport,
sorry for the delay. I think you are pretty close to making it work.
Can you send us a dmesg
log after you activated the driver?
Then are these the device tree files that you have activated ?
Last but not least can you send the results of these two commands?
find /sys -name "*slb9670*"
find /sys -name "*tpm_tis_spi*"
Have a great day!
Kevin
Hello, I will resume the project and I will send you new report
