I referenced the following:
https://hub.docker.com/r/torizon/torizoncore-builder
to start Torizoncore-builder i executed:
alias torizoncore-builder='docker run --rm -it -v $(pwd):/workdir --net=host \
-v /var/run/docker.sock:/var/run/docker.sock torizon/torizoncore-builder'
I then executed “torizoncore-builder build” and received the following error:
Error: Deploy sysroot directory /deploy does not exist.
What needs done to resolve this?
