I am currently trying to create a custom TorizonCore image and I am following this process : TorizonCore Builder Tool - Customizing TorizonCore Images
The problem occur when I launch this command :
torizoncore-builder build
And I get the following response :
Unable to find image 'and:latest' locally docker: Error response from daemon: pull access denied for and, repository does not exist or may require 'docker login': denied: requested access to the resource is denied. See 'docker run --help'.
Of course, I am log in to docker. When I run docker login
, I get this response :
Authenticating with existing credentials... Login Succeeded Logging in with your password grants your terminal complete access to your account. For better security, log in with a limited-privilege personal access token. Learn more at https://docs.docker.com/go/access-tokens/
Thanks for your help
Hi @ClementLerm !
I understand that your docker image is named and
and is tagged as latest
. Is that right?
Also, if you are talking about docker login
, this image should be in your private Docker Hub registry, right?
Can you confirm that you actually pushed the image to your Docker Hub account?
Thanks for your answer.
No, I don’t request any docker image in my tcbuild.yaml
file.
This this actuelly the content of this file :
# Configuration file outline:
input:
easy-installer:
local: images/torizon-core-docker-apalis-imx8-Tezi_5.4.0+build.10.tar
customization:
splash-screen: cormiers.png
output:
easy-installer:
local: torizon-core-docker-apalis-imx8-Tezi_5.4.0.CUSTOM
And at the beginning when I try to run torizoncore-builder build --create-template
, I have the same problem.
Hi @ClementLerm .
That’s quite strange…
What is the version of your TorizonCore Builder?
torizoncore-builder --version
