Torizon WSL 2 doesn't start anymore
I’ve just started my Torizon WSL installed on my windows 11 PC after a couple of weeks.
It doens’t start enymore with the following error:
Welcome to the Torizon WSL 2 v1.0.0
xonsh: For full traceback set: $XONSH_SHOW_TRACEBACK = True
subprocess.CalledProcessError: Command ‘[’/usr/sbin/service’, ‘docker’, ‘status’]’ returned non-zero exit status 3.
Bye!
Last time I started it (a couple of weeks ago) it worked.
How can I fix?
Hi @vix,
try this: Open cmd-shell, type “wsl sudo service docker start”. Then open VSCode.
Hope this helps.
Hi @Lars.ceta
only to be 100% sure, what do you mean with cmd-shell?
A terminal on my windows 11 machine?
…the command prompt (cmd.exe)
Thanks!
It started, and in the log I see
/home/username/.local/pipx/venvs/xonsh/lib/python3.11/site-packages/torizon_templates_utils/errors.py:58: DeprecationWarning: The last attribute is deprecated and will be removed. Use lastcmd.
return xonsh.last.returncode # type: ignore
Docker service OK
Success
Is this expected?
Or is it a bug that toradex should take care of?
I think Toradex is aware of this issue. I hope this will be fixed in the next release.
Glad the workaround work for you.
Just to inform both of you, I brought that deprecation warning to the attention of our team. We will address this when possible.
Thanks.
Only one additional info: the command wsl sudo service docker start is necessary after every new boot of Windows 11 host PC.
This was a known issue, but it has been fixed. It’s likely you may have downloaded and installed the WSL 2 Torizon distro before the fix was applied.
There is a fix you can do for this as posted here: Torizon IDE Extension "Could not activate" - #33 by matheus.tx
Please let us know if this resolves the issue for you.
It seems that the fix works.
I had to reinstall WS"L 2 Torizon distro some weeks ago. It can be that it was before the fix
Glad to hear the fix worked.
