I am having some issues calibrating my touch screen.
I get the following error when launching weston-touch-calibrator. (full log below)
weston-touch-calibrator error: “DPI-1” was not found.
The display and touch work fine on Kiosk mode (just not calibrated). While calibrating all I can see is the default gray scren with time and date on the top right.
We are using a Winstar WF50DTYA3MNG10 panel which has a Goodix GT928
WF50DTYA3MNG10.pdf (1.9 MB)
Could you please point me towards what I need to fix ?
I have read other similar issues posted here but couldn’t find a solution.
I include all the information that was requested by toradex suport in similar issues.
verdin-imx8mm-06944605:~$ uname -r
5.4.129-5.4.0+git.cb88cc157bfb
Taken from torizon-core-docker-verdin-imx8mm-Tezi_5.4.0+build.10 + custom dtbo on top
verdin-imx8mm-06944605:~$ ls -al /dev/input/
total 0
drwxr-xr-x 3 root root 120 Oct 28 10:49 .
drwxr-xr-x 16 root root 4840 Oct 28 10:49 ..
drwxr-xr-x 2 root root 100 Oct 28 10:49 by-path
crw-rw---- 1 root input 13, 64 Oct 28 10:49 event0
crw-rw---- 1 root input 13, 65 Oct 28 10:49 event1
crw-rw---- 1 root input 13, 66 Oct 28 10:49 event2
verdin-imx8mm-06944605:~$ udevadm info /dev/input/event2
P: /devices/platform/soc@0/soc@0:bus@30800000/30a30000.i2c/i2c-1/1-005d/input/input2/event2
N: input/event2
L: 0
S: input/by-path/platform-30a30000.i2c-event
E: DEVPATH=/devices/platform/soc@0/soc@0:bus@30800000/30a30000.i2c/i2c-1/1-005d/input/input2/event2
E: DEVNAME=/dev/input/event2
E: MAJOR=13
E: MINOR=66
E: SUBSYSTEM=input
E: USEC_INITIALIZED=9302298
E: ID_INPUT=1
E: ID_INPUT_TOUCHSCREEN=1
E: ID_INPUT_KEY=1
E: ID_PATH=platform-30a30000.i2c
E: ID_PATH_TAG=platform-30a30000_i2c
E: UDISKS_FILESYSTEM_SHARED=1
E: DEVLINKS=/dev/input/by-path/platform-30a30000.i2c-event
E: TAGS=:power-switch:
verdin-imx8mm-06944605:~$ ls -la /dev/dri
total 0
crw-rw---- 1 root video 226, 0 Oct 28 10:49 card0
crw-rw---- 1 root video 226, 1 Oct 28 10:49 card1
crw-rw-rw- 1 root render 226, 128 Oct 28 10:49 renderD128
verdin-imx8mm-06944605:~$ ls -la /sys/class/drm
total 0
drwxr-xr-x 2 root root 0 Oct 28 10:59 .
drwxr-xr-x 82 root root 0 Oct 28 10:51 ..
lrwxrwxrwx 1 root root 0 Oct 28 11:03 card0 -> ../../devices/platform/38000000.gpu/drm/card0
lrwxrwxrwx 1 root root 0 Oct 28 11:03 card1 -> ../../devices/platform/soc@0/soc@0:bus@32c00000/soc@0:bus@32c00000:display-subsystem/drm/card1
lrwxrwxrwx 1 root root 0 Oct 28 11:03 card1-DSI-1 -> ../../devices/platform/soc@0/soc@0:bus@32c00000/soc@0:bus@32c00000:display-subsystem/drm/card1/card1-DSI-1
lrwxrwxrwx 1 root root 0 Oct 28 11:03 renderD128 -> ../../devices/platform/38000000.gpu/drm/renderD128
-r--r--r-- 1 root root 4096 Oct 28 11:03 version
There are some error messages but works fine after, so I am not sure if the errors are relevant …
verdin-imx8mm-06944605:~$ dmesg | grep Goodix
[ 7.541795] Goodix-TS 1-005d: 1-005d supply AVDD28 not found, using dummy regulator
[ 7.541881] Goodix-TS 1-005d: 1-005d supply VDDIO not found, using dummy regulator
[ 7.653341] Goodix-TS 1-005d: ID 928, version: 1040
[ 7.653458] Goodix-TS 1-005d: Direct firmware load for goodix_928_cfg.bin failed with error -2
[ 7.660622] input: Goodix Capacitive TouchScreen as /devices/platform/soc@0/soc@0:bus@30800000/30a30000.i2c/i2c-1/1-005d/input/input2
Complete log of the weston-touch-calibrator run
verdin-imx8mm-06944605:~$ docker run -ti --rm -e ACCEPT_FSL_EULA=1 --privileged -v /dev:/dev -v /run/udev/:/run/udev/ -v /etc/udev/rules.d:/etc/udev/rules.d torizon/weston-touch-calibrator:$CT_TAG_WESTON_TOUCH_CALIBRATOR
NXP EULA has already been accepted.
Date: 2021-10-28 UTC
[11:28:30.400] weston 9.0.0
https://wayland.freedesktop.org
Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
Build: 9.0.0
[11:28:30.401] Command line: /usr/bin/weston
[11:28:30.401] OS: Linux, 5.4.129-5.4.0+git.cb88cc157bfb, #1-TorizonCore SMP PREEMPT Wed Sep 29 18:17:21 UTC 2021, aarch64
[11:28:30.401] warning: XDG_RUNTIME_DIR "/tmp/weston-xdg" is not configured
correctly. Unix access mode must be 0700 (current mode is 755),
and must be owned by the user (current owner is UID 0).
Refer to your distribution on how to get it, or
http://www.freedesktop.org/wiki/Specifications/basedir-spec
on how to implement it.
[11:28:30.402] Using config file '/etc/xdg/weston/weston.ini'
[11:28:30.403] Output repaint window is 7 ms maximum.
[11:28:30.403] Loading module '/usr/lib/aarch64-linux-gnu/libweston-9/drm-backend.so'
[11:28:30.413] initializing drm backend
[11:28:30.414] logind: not running in a systemd session
[11:28:30.414] logind: cannot setup systemd-logind helper (-61), using legacy fallback
[11:28:30.418] using /dev/dri/card1
[11:28:30.418] DRM: supports atomic modesetting
[11:28:30.418] DRM: does not support GBM modifiers
[11:28:30.418] DRM: supports picture aspect ratio
[11:28:30.419] Loading module '/usr/lib/aarch64-linux-gnu/libweston-9/gl-renderer.so'
[11:28:30.428] EGL client extensions: EGL_EXT_client_extensions
EGL_EXT_platform_base EGL_KHR_platform_wayland
EGL_EXT_platform_wayland EGL_KHR_platform_gbm
[11:28:30.431] EGL version: 1.5
[11:28:30.432] EGL vendor: Vivante Corporation
[11:28:30.432] EGL client APIs: OpenGL_ES OpenVG
[11:28:30.432] EGL extensions: EGL_KHR_fence_sync EGL_KHR_reusable_sync
EGL_KHR_wait_sync EGL_KHR_image EGL_KHR_image_base
EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image
EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image
EGL_EXT_image_dma_buf_import
EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_lock_surface
EGL_KHR_create_context EGL_KHR_no_config_context
EGL_KHR_surfaceless_context EGL_KHR_get_all_proc_addresses
EGL_EXT_buffer_age EGL_ANDROID_native_fence_sync
EGL_WL_bind_wayland_display
EGL_WL_create_wayland_buffer_from_image EGL_KHR_partial_update
EGL_EXT_swap_buffers_with_damage
EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float
[11:28:30.433] EGL_KHR_surfaceless_context available
[11:28:30.437] GL version: OpenGL ES 2.0 V6.4.3.p1.305572
[11:28:30.438] GLSL version: OpenGL ES GLSL ES 1.0.0
[11:28:30.438] GL vendor: Vivante Corporation
[11:28:30.438] GL renderer: Vivante GC7000NanoUltra
[11:28:30.438] GL extensions: GL_OES_vertex_half_float
GL_OES_element_index_uint GL_OES_mapbuffer
GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture
GL_OES_compressed_paletted_texture GL_OES_texture_npot
GL_OES_rgb8_rgba8 GL_OES_depth_texture
GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32
GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap
GL_OES_get_program_binary GL_OES_fragment_precision_high
GL_OES_standard_derivatives GL_OES_EGL_image
GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3
GL_OES_EGL_sync GL_OES_required_internalformat
GL_OES_surfaceless_context GL_OES_texture_border_clamp
GL_EXT_texture_type_2_10_10_10_REV
GL_EXT_texture_compression_dxt1 GL_EXT_texture_format_BGRA8888
GL_EXT_texture_compression_s3tc GL_EXT_read_format_bgra
GL_EXT_multi_draw_arrays GL_EXT_frag_depth
GL_EXT_discard_framebuffer GL_EXT_blend_minmax
GL_EXT_multisampled_render_to_texture GL_EXT_robustness
GL_EXT_texture_sRGB_decode GL_EXT_texture_border_clamp
GL_EXT_texture_rg GL_VIV_direct_texture
[11:28:30.438] GL ES 2 renderer features:
read-back format: BGRA
wl_shm sub-image to texture: no
EGL Wayland extension: yes
[11:28:30.447] event1 - gpio-keys: is tagged by udev as: Keyboard
[11:28:30.447] event1 - gpio-keys: device is a keyboard
[11:28:30.451] event0 - 30370000.snvs:snvs-powerkey: is tagged by udev as: Keyboard
[11:28:30.451] event0 - 30370000.snvs:snvs-powerkey: device is a keyboard
[11:28:30.455] event2 - Goodix Capacitive TouchScreen: is tagged by udev as: Keyboard Touchscreen
[11:28:30.455] event2 - Goodix Capacitive TouchScreen: device is a keyboard
[11:28:30.455] event2 - Goodix Capacitive TouchScreen: device is a touch device
[11:28:30.474] libinput: configuring device "gpio-keys".
[11:28:30.474] libinput: configuring device "30370000.snvs:snvs-powerkey".
[11:28:30.474] Touchscreen - Goodix Capacitive TouchScreen - /sys/devices/platform/soc@0/soc@0:bus@30800000/30a30000.i2c/i2c-1/1-005d/input/input2/event2
[11:28:30.474] libinput: configuring device "Goodix Capacitive TouchScreen".
[11:28:30.474] input device event2 has no enabled output associated (none named), skipping calibration for now.
[11:28:30.475] DRM: head 'DSI-1' found, connector 35 is connected, EDID make 'unknown', model 'unknown', serial 'unknown'
[11:28:30.475] Registered plugin API 'weston_drm_output_api_v1' of size 24
[11:28:30.475] Registered plugin API 'weston_drm_virtual_output_api_v1' of size 48
[11:28:30.485] Chosen EGL config details: id: 41 rgba: 8 8 8 0 buf: 24 dep: 0 stcl: 0 int: 1-60 type: win|pix|pbf|swap_preserved vis_id: XRGB8888 (0x34325258)
[11:28:30.485] Output DSI-1 (crtc 33) video modes:
720x1280@58.3, preferred, current, 60.0 MHz
[11:28:30.485] associating input device event1 with output DSI-1 (none by udev)
[11:28:30.485] associating input device event0 with output DSI-1 (none by udev)
[11:28:30.485] associating input device event2 with output DSI-1 (none by udev)
[11:28:30.486] Output 'DSI-1' enabled with head(s) DSI-1
[11:28:30.486] Compositor capabilities:
arbitrary surface rotation: yes
screen capture uses y-flip: yes
presentation clock: CLOCK_MONOTONIC, id 1
presentation clock resolution: 0.000000001 s
[11:28:30.487] Loading module '/usr/lib/aarch64-linux-gnu/weston/desktop-shell.so'
[11:28:30.488] launching '/usr/lib/aarch64-linux-gnu/weston-keyboard'
[11:28:30.492] Loading module '/usr/lib/aarch64-linux-gnu/libweston-9/xwayland.so'
[11:28:30.514] Registered plugin API 'weston_xwayland_v1' of size 32
[11:28:30.514] Registered plugin API 'weston_xwayland_surface_v1' of size 16
[11:28:30.515] xserver listening on display :0
[11:28:30.516] launching '/usr/lib/aarch64-linux-gnu/weston-desktop-shell'
could not load cursor 'dnd-move'
could not load cursor 'dnd-copy'
could not load cursor 'dnd-none'
weston-touch-calibrator error: "DPI-1" was not found.
Thanks,
Jaume
