When viewing the Device Information for a single board, if you click on the options for the CPU Temperature and then uncheck the Connect series check, the chart is rendered but no points are put on the chart. The same problem occurs with the CPU Usage, Docker Service Status and Memory Usage.
Torizon OTA dashboard doesn't display anything for the CPU temperature if you uncheck Connect Series
Greetings @toebes,
I’m observing the same issue on my side as well. This was a known issue in the past but, perhaps it has resurfaced again. Let me report this to the team.
