Torizon OS SBOM validation not passing
We are interested in getting VEX-enriched SBOMs with CVE analysis from Toradex for Torizon OS releases. By downloading one from the Torizon Cloud and putting it into an SBOM checker (for example, sbomaudit, but I’ve also tried NTIA SBOM Validator), the SBOM does not pass some of them.
For us, the must-pass check is the NTIA minimal elements one. But the SBOM itself must be a valid one as well.
My question/request is: does Toradex plan to validate their SBOMs for Torizon Cloud users?
Sample validation output of Torizon OS 7.6.1+build.38 for am62 is attached. There are various errors there, not only the NTIA minimal elements one.
foo.out (25.4 KB)
Based on the information sources, Torizon provides both complete and actionable SBOMs for every Torizon OS release. Toradex publishes SBOMs in two formats: a complete SBOM in SPDX format and an actionable SBOM in CycloneDX format(1).
SBOM Formats and Standards
Torizon provides different SBOM formats for different purposes(1):
  • SPDX SBOM: Generated by Yocto’s create-spdx class, listing Yocto package names and versions based on the PN and PV variables, including every file in the filesystem with its hash(1)
  • CycloneDX SBOM: Makes use of extra data from Yocto’s cve-check class, enriching the SBOM with information about security patches applied to each package and correcting package names and versions to match vulnerability database formats(1)
VEX-Enriched SBOMs
The CycloneDX SBOM is specifically designed to be much better suited for vulnerability management(1). Torizon Vulnerability Manager provides all of its data in standards-compliant VEX format, allowing you to download files with Torizon analysis and import them into your own tools(2).
Current SBOM Availability
You can download both SBOMs from Toradex’s Artifactory instance at specific paths for your System On Module (SoM) and Torizon release(1). The documentation shows the exact file paths and provides examples using standardized tooling like cve-bin-tool(1).
Regarding your specific question about NTIA minimal elements validation and whether Toradex plans to validate their SBOMs for compliance with these standards - this specific validation information isn’t covered in the available documentation sources.
For detailed information about SBOM validation compliance plans and addressing the specific validation errors you encountered with Torizon OS 7.6.1+build.38, I’d recommend reaching out through the Toradex Community where you can get direct support from the Torizon team regarding SBOM validation standards and any planned improvements.
I’ve noticed based on the SBOM article that there are two SBOMs, one referential and one for VEX annotations. The merged SPDX one doesn’t validate either, you can try e.g. this one and the SPDX validator.
Based on the information sources, I can confirm that Torizon publishes SBOMs in two different formats for different purposes (1):
SBOM Generation and Formats
The SPDX SBOM is generated by Yocto’s create-spdx class, which lists Yocto package names and versions based on the PN and PV variables, but does not give a CPE or PURL (1). It also lists every file in the filesystem and its hash (1).
The CycloneDX SBOM makes use of extra data from Yocto’s cve-check class, which adds critical information that isn’t easily discoverable from the SPDX SBOM (1). For example, it enriches the SBOM with information about the security patches that were applied to each package, and corrects many package names and versions to match the format that vulnerability databases expect (1).
SBOM File Locations
For each build of Torizon OS, both SBOMs are published to Toradex’s Artifactory instance (1). The file paths are structured as follows:
# SPDX SBOM
torizoncore-oe-prerelease-frankfurt/<bsp-release>/<release-period>/<release-build-number>/<som>/<torizon-distro>/<torizon-image>/oedeploy/<torizon-image-som-release_code>.spdx
# CycloneDX SBOM
torizoncore-oe-prerelease-frankfurt/<bsp-release>/<release-period>/<release-build-number>/<som>/<torizon-distro>/<torizon-image>/oedeploy/bom.json
(1)
Validation Tools
The documentation mentions that you can download and parse these documents using standardized tooling for each format, such as cve-bin-tool (1):
$ wget "https://artifacts.toradex.com:443/artifactory/<sbom-file-path>" -O sbom.spdx
$ cve-bin-tool --sbom spdx --sbom-file sbom.spdx
$ wget "https://artifacts.toradex.com:443/artifactory/<sbom-file-path>" -O bom.json
$ cve-bin-tool --sbom cyclonedx --sbom-file bom.json
(1)
However, the documentation doesn’t specifically address SPDX validation compliance with external validators like the SPDX validator tool you mentioned. The validation issues you’re encountering with the SPDX SBOM files appear to be a technical matter that would benefit from direct engagement with the Torizon development team.
For specific validation compliance issues and potential improvements to SBOM generation to meet SPDX validation standards, I’d recommend discussing this directly on the Toradex Community where the development team can address the technical aspects of SBOM validation compliance.
Hello @vilchanskyio,
Thanks for the additional information and for testing both the SPDX and merged VEX-enriched SBOMs with external validation tools.
We have started an internal investigation to better understand the reported validation issues, including the NTIA Minimal Elements checks and the SPDX validator findings. At the moment, we are reviewing the SBOM generation process and the reported validation output to determine whether these are limitations of the current tooling, gaps in our generation pipeline, or issues that can be addressed through post-processing.
We’ll follow up here once we have more information from the team.
Thanks for bringing this to our attention.
Quick follow-up on the internal investigation. Your findings are valid, and the response below focuses on CycloneDX since that is what you tested.
Two items are on our side to address. First, the top-level metadata: metadata.component is not populated with Torizon OS as the root, and our supplier information is missing. This is responsible for most of the NTIA validator errors and is a reasonable fix. Second, orphan packages: adding a root-level torizon-os component that depends on the package set should clear the dependency-relationship warnings.
The supplier field for upstream OSS components is a separate matter. There is no reliable automated way to attribute a supplier to every OSS component across Yocto recipes, and this is not specific to our pipeline. PURL and CPE give us a starting point, but full coverage across thousands of upstream packages is not realistic in the short term.
On the broader question of NTIA conformance: Torizon OS sits inside a finished product, and NTIA validation is typically performed at the final product level, where the integrator aggregates our OS SBOM with their own application, hardware BOM, and supplier metadata. We will still close the validation gaps we can close on our side, but full NTIA conformance for the OS image in isolation is not the natural target for this kind of SBOM.
We will report back here once the metadata and root-component changes are merged.
Hi, is anyone working on this currently?
Regarding the supplier, when I worked on a custom BSP (not related to Toradex), I just attributed the supplier to the Yocto Project, and if a component did not have a specific lifetime/support schedule, I used the Yocto release support schedule. Of course, this is wrong, but it’s at least something.
Regardless, least we would expect, in terms of cybersecurity compliance, are the Toradex-published SBOMs to validate error-free in general, and on the minimal elements being present.
Yes, this is still active on our side. The discussion is currently with our Principal Product Security Architect, and we are waiting on his input before committing to the specific changes and a timeline.
On the supplier fallback for upstream OSS components, the Yocto Project approach you described is a reasonable default and we are considering something similar. Beyond that, our SBOMs are generated with standard Yocto tooling (create-spdx, cve-check, and the CycloneDX exporter) and the artifacts parse cleanly in our internal vulnerability analysis. Where a specific external validator flags something the standard tooling emits, we can look at it case by case, but we cannot commit upfront to error-free output across every third-party validator.
I will follow up here once the metadata and root-component changes land.
Hello @vilchanskyio ,
We completed the internal review of this topic.
The SBOM artifacts published for Torizon OS are generated using the standard tooling integrated into our Yocto-based build process. We also consume these artifacts in Toradex’s own vulnerability analysis workflow, and we have not observed issues parsing the generated CycloneDX bom.json in that process.
That said, we currently do not guarantee that the published SBOMs will pass every third-party validator or a specific compliance profile such as the NTIA Minimum Elements checks. Different tools may impose additional requirements or interpretations beyond what is produced by the underlying Yocto tooling.
For this reason, we are not currently committing to post-processing the SBOMs specifically to satisfy individual external validators. If a validator identifies an issue that represents a concrete violation of the underlying SPDX or CycloneDX specification, rather than an additional policy/profile requirement, we can evaluate that separately and determine whether the appropriate fix belongs in our generation pipeline or upstream tooling.
We are also reviewing how we document the tools and processing used for the SBOMs so that the expected format and intended consumption are clearer.
Thanks again for reporting the validation results and providing the examples.
