Torizon OS 7.6.0 Quarterly Release
We are pleased to announce the content of Torizon OS 7.6.0 quarterly release for Toradex’s System on Modules.
Torizon OS is our operating system that powers Torizon, a DevOps platform that simplifies the development and maintenance of embedded Linux software. Torizon OS is designed to be used out-of-the-box on devices requiring high reliability, allowing you to focus on your application instead of building and maintaining an operating system.
Torizon uses software containers, making it simple to add functionality to your system in a way that is both secure and easy to maintain. Torizon supports hardware acceleration in containers and graphical user interfaces.
Updates and Highlights
Torizon OS
Common Torizon
  • Distro updates:
    • Added Luna SL1680 Board quarterly release.
    • Added Astra Machina SL1680 quarterly release.
    • Added NVIDIA Jetson Orin Nano engineering pre-release.
Get started with Common Torizon on supported hardware.
Debian Packages and Containers
Full release notes are published in the Torizon Containers repository: Torizon Containers Release Notes.
Highlights
Intended Use
The Torizon OS 7.6.0 Quarterly Release is a production-grade release.
Therefore, if you are in production with TorizonCore 5, Torizon OS 6 or earlier Torizon OS 7 releases, we recommend moving to this quarterly release. Learn more in the Torizon Upgrade Notes.
For more details click here: Torizon OS 7.6.0 Quarterly Release
