I did a search through the forum and did not find anything that references neofetch. This utility was available in the base v5. Has it been removed for for v7? I assume it can’t be added to the base OS without creating a custom build?
Hello there!
It seems that there isn’t specific information about the ‘neofetch’ package in the Torizon OS 7 documentation. However, you can certainly add additional packages to your Torizon OS by customizing the image using TorizonCore Builder.
Here’s a brief guide on how you can do this:
Make Changes on Your Device: First, make the necessary changes on your target device, such as installing the ‘neofetch’ package.
Capture Changes: Use the
isolate
command to capture these changes. Here’s an example command:$ torizoncore-builder isolate --remote-host 192.168.1.10 --remote-username torizon --remote-password torizon --changes-directory changes1
Create a Custom Image: Include these changes in your custom image configuration. Below is a sample configuration:
input: easy-installer: local: images/torizon-core-docker-colibri-imx6-Tezi_5.3.0-devel-202105+build.12.tar customization: filesystem: - changes1/ output: easy-installer: local: torizon-core-docker-colibri-imx6-cg
This process allows you to tailor the Torizon OS to include additional packages like ‘neofetch’.
If you have any more questions or need further assistance, feel free to ask!
Greetings @Glitch,
Please see the upgrade notes for Torizon here: Torizon OS Upgrade Notes | Toradex Developer Center
Under 7.0.0 you can see:
In the OS, neofetch has been replaced with fastfetch. In the Debian Containers for Torizon, it is scheduled to be replaced as well. As this is a development utility, no real impact is expected with this change.
Fastfetch is more or less a more polished, modern replacement for neofetch. Other than the name change there should be no major usability differences.
