Since yesterday, I am not able any more to “build the release or debug container” in Torizon 1.4.0 (VScode).
When I invoke the palette (F1) on vscode Torizon : build release container for the application
, it fails with Local deployment task failed.
after a few seconds.
Actually, the release container is not even built (there is only 4 seconds between build and deployment, so deployment failed because no image is built).
The work/Dockerfile.release
or work/Dockerfile.debug
is not even re-generated.
The complete OUTPUT
message is :
[03-01 10:21:36.893] Initializing Torizon Extension
[03-01 10:21:36.912] Checking system setup...
[03-01 10:21:36.913] Checking Moses ...
[03-01 10:21:37.035] Starting backend local instance running on port 5001
[03-01 10:21:49.181] Torizon Backend version 1.0.0 API version: 1.1.5
[03-01 10:21:49.183] Torizon IDE backend started
[03-01 10:21:49.184] Checking Docker ...
[03-01 10:21:49.242] Docker version 20.10.13 build 906f57f
[03-01 10:21:49.318] Trying connect to Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Board(06852340)
[03-01 10:21:50.498] Active configuration has been selected 513050ae-f541-4a8a-baef-1599a9e43911, updating it.
[03-01 10:21:50.501] Initializing Torizon C/C++ application.
[03-01 10:21:50.919] SDK-related features are enabled for this project.
[03-01 10:21:50.946] Torizon: Qt5 arm64v8-vivante bullseye - phosddvr - 513050ae-f541-4a8a-baef-1599a9e43911
[03-01 10:21:50.948] Torizon Extension Initialized
[03-01 10:21:50.986] LA_OPT_NXP_Software_License v5 January 2019 EULA accepted
[03-01 10:22:04.622] Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Board(06852340) connected
[03-01 10:22:04.623] Torizon: all devices refreshed
[03-01 10:23:41.395] Preparing debug environment for C/C++ application...
[03-01 10:23:41.396] Your current build configuration is set to release, this may prevent generation of debugging symbols or enable optimization that prevent debugging features like breakpoints, watches or call stack from working or showing correct inforamation.
[03-01 10:23:41.403] Running preLaunchTask build_release...
[03-01 10:24:00.544] preLaunchTask completed.
[03-01 10:24:05.383] Local deployment task failed.
[03-01 10:24:21.267] Building release container for C/C++ application...
[03-01 10:24:25.971] Local deployment task failed.
Note that I did a deep rechecking before writing this message :
- the SDK container builds and run correctly, and my application compiles nicely.
- the target device (apalis-iMX8) is working nice and can be accessed.
- I even erased all my Docker images and reflashed the SoC to start from scratch again.
But still it does not work (but it used to work before yesterday!).
I cannot find any useful information in the logs. But I am not quite sure what log I should look to.
Could you give me some hints to find more relevant output messages in order to debug this issue ?
Fabian
