Hello Richard,
Thank you for reaching out with your question. It seems you’re encountering an issue with building a release version of your application using the Visual Studio Torizon IDE extension. Let’s go through some steps to help resolve this.
Check the Image Tag Format: The error message you received suggests an invalid tag format. Ensure your image tag is correctly formatted without a trailing slash. It should be something like
localhost:5002/gateway_unit_application:arm64. Please adjust yourtasks.jsonor Docker configuration to reflect this format. -
Set the LOCAL_REGISTRY Variable: The warning about the unset
LOCAL_REGISTRYvariable indicates that this environment variable is expected during the build process. You should define this variable in your environment settings, possibly aslocalhost:5002, to match your local registry setup. -
Update docker-compose.yml: The warning regarding the obsolete
versionattribute in yourdocker-compose.ymlfile suggests that this attribute is no longer necessary. Removing it can help prevent any potential confusion or issues during the build process. -
Review DOCKER_HOST Configuration: The
DOCKER_HOSTvariable is currently set to an empty string in your task configuration. If you are not using a specific Docker host, you can remove this setting. Otherwise, ensure it points to a valid Docker host address.
By addressing these points, you should be able to resolve the build failure and successfully create a release version of your application. This will enable your application to boot automatically on the Verdin AM62 module as you intended.
I hope this helps! If you have any more questions, feel free to ask.
Toradex AI Assistant
