Torizon IDE extension: try-update-template fails
I’ve just installed a fresh Windows 11 PC and I set up Torizon IDE Extension (v 3.3.0) following these steps.
I did checkout of my torizoncore-builder project (that I use successfully on my old PC inside a ubuntu 22-04 WSL distro.
And I took the opportunity of new PC to updating everything.
So I run try-update-template task, but it fails with the following log:
Executing task: pwsh -nop /home/username/repo/tcb_project/.conf/projectUpdater.ps1 /home/username/repo/tcb_project tcb_project 0
⚠️  project updater updated, running it again
Your template is on Torizon OS version 6 and you are updating it to a template in Torizon OS version 7
Are you sure you want to proceed with the update? [y/n]: y
⚠️  On Torizon 7, the scripts are moved from powershell to a Python shell (https://xon.sh/). So, removing the powershell scripts…
🐚 SETUP XONSH
xonsh is already installed, updating torizon-templates-utils …
Collecting git+https://github.com/torizon/vscode-torizon-templates.git@main#subdirectory=scripts/utils/pip
Cloning
 (to revision main) to /tmp/pip-req-build-k55_zblb
Running command git clone --filter=blob:none --quiet
Did not find branch or tag ‘main’, assuming revision or ref.
Running command git checkout -q main
error: pathspec ‘main’ did not match any file(s) known to git
error: subprocess-exited-with-error
× git checkout -q main did not run successfully.
│ exit code: 1
╰─> No available output.
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed to build ‘git+https://github.com/torizon/vscode-torizon-templates.git@main#subdirectory=scripts/utils/pip’ when git checkout -q main
‘/home/username/.local/pipx/venvs/xonsh/bin/python -m pip install --force-reinstall git+https://github.com/torizon/vscode-torizon-templates.git@main#subdirectory=scripts/utils/pip’ failed
all ok ✅
The latest Torizon OS major version is 7
But your templates repository is using the major version 6.
Check the torizon.templatesBranch property in your settings.json
Your template is on Torizon OS major version 6 and you are updating it to a template in Torizon OS major version 7
Are you sure you want to proceed with the update? [y/n] y
✅ Latest scripts and documentation merged
xonsh: To log full traceback to a file set: $XONSH_TRACEBACK_LOGFILE =
File “/home/username/repo/tcb_project/.conf/project-updater.xsh”, line 477, in
_update_table = _update_table.replace(“$projectName”, project_name)
TypeError: replace() argument 2 must be str, not None
❌ Error updating the project
The terminal process “pwsh ‘-nop’, ‘/home/username/repo/tcb_project/.conf/projectUpdater.ps1’, ‘/home/username/repo/tcb_project’, ‘tcb_project’, ‘0’” terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
The issue you’re encountering appears to be related to the project update process when migrating from Torizon OS 6 to Torizon OS 7. The error TypeError: replace() argument 2 must be str, not None suggests that the project_name variable is None during the update process.
Root Cause Analysis
The error occurs in the project-updater.xsh script when it tries to replace $projectName with a None value(1). This script is used to update projects to the latest version of the template source(1).
Troubleshooting Steps
1. Check Project Metadata
First, verify your project’s metadata file contains the required information:
Check the .conf/metadata.json file in your project directory(1). This file should contain:
  • projectName: The name you input when creating the project
  • templateName: The name of the template source folder
  • containerName: The container name you input when creating the project
  • torizonOSMajor: The major version of Torizon OS(1)
2. Verify Project Structure
Ensure your project has the proper workspace structure with all required files in the .conf directory(1):
  • .conf/metadata.json
  • .conf/project-updater.xsh
  • .conf/update.json
3. Manual Metadata Fix
If the metadata.json file is missing or corrupted, you may need to recreate it with the proper structure:
    "projectName": "your-project-name",
    "templateName": "your-template-name",
    "containerName": "your-container-name",
    "torizonOSMajor": "6"
(1)
4. Alternative Approach
Since you’re migrating from Torizon OS 6 to 7, consider creating a new project with the Torizon OS 7 template and manually migrating your application code, as the update process involves significant changes including the migration from PowerShell to Python shell (xonsh)(1).
The workspace structure documentation indicates that the project-updater.xsh script uses data from metadata.json to update projects(1), so ensuring this file is properly formatted is crucial for successful updates.
Greetings @vix,
Could you share the initialization logs of our extension. We want to make sure everyone looks correct, and sane on startup.
Hi @jeremias.tx
Here are the logs
[02-20 17:57:21.490] Activating Torizon IDE …
[02-20 17:57:21.490] Torizon IDE version :: 3.3.0
[02-20 17:57:22.818] Latest Torizon IDE published :: 3.3.113
[02-20 17:57:22.818] Telemetry is enabled
[02-20 17:57:22.818] Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you’d not like to share any information. Check: Settings - Data Collection | Toradex Developer Center
[02-20 17:57:22.818] Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
[02-20 17:57:22.818] Resolving host IP address …
[02-20 17:57:23.916] Host IP address OK
[02-20 17:57:23.916] Bash as default shell OK
[02-20 17:57:23.934] Docker installed OK
[02-20 17:57:24.050] Docker running OK
[02-20 17:57:24.201] Docker compose OK
[02-20 17:57:24.210] PowerShell OK
[02-20 17:57:24.218] git OK
[02-20 17:57:24.227] dig OK
[02-20 17:57:24.236] avahi-resolve OK
[02-20 17:57:24.247] nmap OK
[02-20 17:57:24.256] iputils-ping OK
[02-20 17:57:24.265] file OK
[02-20 17:57:24.274] sshpass OK
[02-20 17:57:24.338] iproute2 OK
[02-20 17:57:24.350] rsync OK
[02-20 17:57:24.379] python3 OK
[02-20 17:57:24.389] pipx OK
[02-20 17:57:24.390] Cloning project templates
[02-20 17:57:24.390] Templates repo: GitHub - torizon/vscode-torizon-templates: VS Code Torizon Integrated Development Environment Templates
[02-20 17:57:24.390] Templates branch: bookworm-7
[02-20 17:57:24.390] Templates tag/hash: tos7
[02-20 17:57:24.400] Project templates clone of branch bookworm-7 OK
[02-20 17:57:24.726] Project templates fetched OK
[02-20 17:57:24.742] Checkout templates repo to tag origin/bookworm-7 OK
[02-20 17:57:30.490] xonsh installation OK
[02-20 17:57:30.490] WARNING :: Project name not found in workspace metadata for single container workspace, or it matches the workspace name.
[02-20 17:57:30.491] Checking connected devices …
[02-20 17:57:30.491] Scanning Torizon devices …
[02-20 17:57:30.499] Debian bookworm packages list load OK
[02-20 17:57:30.499] Debug id_rsa OK
[02-20 17:57:30.895] Torizon IDE extension activated
After discussing with the team, we believe we know what the issue is here.
Your old project seems to have been created when our extension still used powershell scripting to facilitate it’s use. The current project templates that you are trying to update to, now use xonsh instead of powershell.
According to our team, because of this some aspects are not migrated perfectly and can cause issues like what you’re seeing here. The team will work to improve the migration behavior between the older powershell templates and the current xonsh templates.
For now though, the best solution would be to just create a new project, using the new templates. Then just copy your code/work over from your old project into the new project manually. Apologies for the inconvenience.
Yes, I confirm this.
I’ll do this and I let you know in case I need help (powershell is a known tool for me; I don’t have experience with xonsh).
  1. The first thing that I want to report is that the default settings.json file for torizoncore-builder project contains a “docker_tag” item. But I don’t think it’s necessary.
    Can this be removed?
  2. The second one:
    does a tcb-bundle task exists in the new template? If not, how can I write it?
  3. Why both the workspace name and tcb.packageName cannot contain _ and - chars for a tcb project? I can understand the packageName for a docker project, but I can’t see nay reason for tcb
This is just an extraneous setting that gets pulled into every project as a “common” setting. For TCB it can be ignored. Your feedback was passed to our VSCode IDE team.
This task was removed as it’s expected that everything be done through the build command and it’s yaml file. Otherwise if you want to re-implement this for some reason, this commit is the one that removed the task: Add task tests for tcb template · torizon/vscode-torizon-templates@b47f52b · GitHub
This is just a common rule enforced on all project types to avoid having to create special cases or exceptions on a per-project basis.
Do you know if something has been improved in the migration (in the meanwhile)?
The team has been working on improving this, but nothing that is publicly available yet.
Thanks.
I’ve just tried to create a new project and copy my code, but I can’t find a way to get it working.
I’m confused about what I see in the new project and in the errors that I get.
Can we find a way that you (or someone else) can support me directly?
Could you describe the exact process you’re performing and the errors you are getting. Then we can try to find the correct person to assist you on this.
Hi @jeremias.tx
  • I create a new tcb project with the IDE extension in WSL
  • I copy my files from the existing project (no scripts, …)
  • I try to build
  • I get error torizoncore-builder workdir must not exists
I discussed this at length with our IDE extensions team. We’re a bit confused actually, specifically on where this log line torizoncore-builder workdir must not exists originates from.
We couldn’t find a match for this error log anywhere in TorizonCore Builder itself, or in the VSCode extension logic. Without knowing where this log line is being produced from it’s difficult to debug what exactly is going on.
Are you sure this is the exact error log that was produced? Could you perhaps share more of the logs from the build process so we have a complete picture.
Also when you say you “copied” your files from the old project, you didn’t copy over any configuration files like settings.json yes? You only copied the input files for TorizonCore Builder I assumed. Otherwise, mixing configuration files from an old project into a new project could cause strange results.
