Hi there,
After running “run-container-torizon-release-arm64”, I would like to deploy the containers to several target units without having to re-build all again and again. Maybe that’s already possible but I don’t know how…
Thanks in advance
V
Hi there,
Thanks in advance
V
You can deploy your already-built container images to multiple target devices without rebuilding. Here are your options:
After building your release container with run-container-torizon-release-arm64, push it to a container registry once, then pull and run it on each target device(1).
Steps:
From each target device’s terminal:
docker pull your-registry/your-image:tag
docker run your-registry/your-image:tag
Package your container image as a tar file and transfer it to each device(1):
On your development machine:
docker save -o myapp.tar your-image:tag
Transfer the tar file to each target device, then:
docker load -i myapp.tar
docker run your-image:tag
For production deployments to multiple devices, use Torizon Cloud(1):
This approach is particularly efficient for managing multiple devices and allows you to deploy simultaneously to your entire fleet without manually accessing each device(1).
Toradex AI Assistant
Greetings @vic,
As the AI has suggested, if you want to deploy to several devices, it’s probably easier to just push your container images to a container registry (i.e Docker Hub) and pull the images on each device.
Would this suffice for your needs? Or does your use-case require something else?
