Hi @ompie !
Your issue is still strange
If you think this is related to some âcontainer environmentâ, you can try to remove all the related Docker images that you have in the âfaulty PCâ.
You can go to your terminal and use the docker images
(or docker image list
) command to list all Docker images that you have and use the docker rmi
command to remove images.
Then, you might need to go to VSCode and rebuild the necessary containers again:
I would try the following order:
- Rebuild Dev Container
- Rebuild SDK
- Rebuild Application Container (the âBuild debug containerâ)
Let us know how it goes
