My unit was giving the error described here: Exception related error messages in .NET | Toradex Developer Center
so I installed the ToradexNETCFv35.Messages.EN.cab file.
The problem is that Visual Studio now uploads the cab file to the system on every startup - which takes 10s of seconds. Also, if I stop debugging the system will not restart debugging until I restart the T20 unit. It gives the error: “The parameter is incorrect.”
How can I speed up the deployment and avoid this problem?
Thanks,
Sam
