Toradex EZ instaler on Verdin I.MX8M Plus
We have just received a new Verdin i.mx8M Plus as well as its Verdin carrier board (V1.1A). It has the multimedia image installed by default:
root@verdin-imx8mp:~# hostnamectl
   Static hostname: verdin-imx8mp
         Icon name: computer
        Machine ID: c065814c757b460ea7d0a6398a080957
           Boot ID: 81b3e0b84c6043d88fc8df24f90b8909
  Operating System: TDX Wayland with XWayland 5.2.0-devel-202103+build.8 (dunfell)
            Kernel: Linux 5.4.91-5.2.0-devel+git.c59b3c2da1e9
      Architecture: arm64
I could generate an EZ installer image with Yocto and would like to install it. Unfortunately, I was not able to start the Toradex EZ installer, the process just hangs:
Verdin-iMX8MM_ToradexEasyInstaller_2.0b7-20210415 ➞ ./recovery-linux.sh
Downloading Toradex Easy Installer...
Password:
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.43-0-ga9c099a
Success 0    Failure 0
1:6114   1/ 0 [                                      ]
The CPU seems to be in bootstrap mode since it is recognized by listing devices:
./recovery/uuu -lsusb
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.127-0-ga9c099a
Connected Known USB Devices
	Path	 Chip	 Pro	 Vid	 Pid	 BcdVersion
	1:6114	 MX865	 SDPS:	 0x1FC9	0x0146	 0x0002
If I try to load the bootloader manually, it fails with an USB error:
sudo ./recovery/uuu imx-boot
Success 0    Failure 1
1:6114   1/ 2 [HID(W):LIBUSB_ERROR_IO                ] SDPS: boot -f "imx-boot"
I didn’t find any release for the i.mx8 plus and consequently work with the mini release, wondering if that could be an issue. Another difference with what I could find on your documentation is that it has USB C instead of micro USB but it should probably not be a big deal … right?
  • Is there something I’m doing wrong or missing?
  • Is is officially supported on Verdin i.mx8m plus?
Thanks for the pointers!
Ok guys, sorry I should have read better, I found this page:
And could successfully flash my wic image from yocto using the bmaptools!
Perfect that you found the correct Information. Thanks for the feedback.
