I tried to install custom tezi image on Apalis iMX6Q IT 2GB module by ToradexEasyInstaller(v1.0-20170605). It printed error from console
U-Boot 2016.11-1.0.0+g0e9e31a (Jun 05 2017 - 16:38:56 -0700)
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: WDOG
I2C: ready
DRAM: 2 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
Using default environment
In: serial_mxc
Out: serial_mxc
Err: serial_mxc
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1B, Serial# 04958409
Serial Downloader recovery mode, using sdp command
Net: using PHY at 7
FEC [PRIME]
SDP: initialize...
SDP: handle requests...
Downloading file of size 20408300 to 0x12100000... EP0/out FAIL info=4018080 pg0=8df78500
ERROR: Unexpected report 4
at /build/ags/oe-core_tezi_morty/build/tmp-glibc/work/apalis_imx6-oe-linux-gnueabi/u-boot-toradex/2016.11-1.0.0-gitr0e9e31a/git/)
Downloading file of size 367 to 0x12000000... done
Jumping to header at 0x12000000
Header Tag is not a IMX image
## Loading kernel from FIT Image at 12100000 ...
Bad FIT kernel image format!
ERROR: can't get kernel image!
But on PC, it said it’s successful.
ben@LinuxDev:~/Tezi/Apalis-iMX6_ToradexEasyInstaller_1.0-20170605$ ./recovery-linux.sh
Downloading Toradex Easy Installer...
Successfully downloaded Toradex Easy Installer.
Do you what the problem is? Thanks very much!
