i am using Ubuntu 16.04 PC connected to x22 uart { serial port of carrier board }
i am booting Apalis module through serial port using a tool PICOCOM .
how i run while the resetting process is going on { after the command bmode usb }…
{ having only one Ubuntu PC & Apalis module } did u mean i need any another PC like that , where i should run the ./recovery-linux.sh connected through usb port
One PC in general should do but you need connecting both the console UART as well as the USB device interface to your PC where in the console terminal you do bmode usb just like you did plus then open another terminal shell on that same PC running the ./recovery-linux.sh script.
