@DaveM Is this the log output you wanted to check,
--- Starting bitbake server pid 4874 at 2021-12-16 19:55:25.125330 ---
Started bitbake server pid 4874
Entering server connection loop
Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([])
Processing Client
Connecting Client
Running command ['setFeatures', [2, 1]]
Running command ['updateConfig', {'dump_signatures': [], 'profile': False, 'debug': 0, 'postfile': [], 'build_verbose_shell': False, 'extra_assume_provided': [], 'server_timeout': None, 'prefile': [], 'force': False, 'dry_run': False, 'build_verbose_stdout': False, 'debug_domains': [], 'invalidate_stamp': None, 'abort': True}, {'PWD': '/home/unknown/oe-core/build', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'DEFAULTS_PATH': '/usr/share/gconf/ubuntu.default.path', 'LOGNAME': 'unknown', 'GTK2_MODULES': 'overlay-scrollbar', 'XDG_SESSION_PATH': '/org/freedesktop/DisplayManager/Session0', 'XDG_GREETER_DATA_DIR': '/var/lib/lightdm-data/unknown', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'UPSTART_EVENTS': 'started starting', 'XDG_SESSION_TYPE': 'x11', 'GPG_AGENT_INFO': '/home/unknown/.gnupg/S.gpg-agent:0:1', 'COMPIZ_CONFIG_PROFILE': 'ubuntu', 'XDG_RUNTIME_DIR': '/run/user/1000', 'XDG_SESSION_DESKTOP': 'ubuntu', 'GTK_IM_MODULE': 'ibus', 'SHELL': '/bin/bash', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'USER': 'unknown', 'JOB': 'gnome-session', 'UPSTART_INSTANCE': '', 'QT_LINUX_ACCESSIBILITY_ALWAYS_ON': '1', 'MANDATORY_PATH': '/usr/share/gconf/ubuntu.mandatory.path', 'BB_ENV_EXTRAWHITE': 'ALL_PROXY BBPATH_EXTRA BB_LOGCONFIG BB_NO_NETWORK BB_NUMBER_THREADS BB_SETSCENE_ENFORCE BB_SRCREV_POLICY DISTRO FTPS_PROXY FTP_PROXY GIT_PROXY_COMMAND HTTPS_PROXY HTTP_PROXY MACHINE NO_PROXY PARALLEL_MAKE SCREENDIR SDKMACHINE SOCKS5_PASSWD SOCKS5_USER SSH_AGENT_PID SSH_AUTH_SOCK STAMPS_DIR TCLIBC TCMODE all_proxy ftp_proxy ftps_proxy http_proxy https_proxy no_proxy ', 'XAUTHORITY': '/home/unknown/.Xauthority', 'GDM_LANG': 'en_US', 'XDG_VTNR': '7', 'VTE_VERSION': '4205', 'INSTANCE': 'Unity', 'XDG_SEAT': 'seat0', 'QT_QPA_PLATFORMTHEME': 'appmenu-qt5', 'TERM': 'xterm-256color', 'LANG': 'en_IN', 'QT_IM_MODULE': 'xim', 'GNOME_KEYRING_PID': '', 'QT4_IM_MODULE': 'xim', 'XMODIFIERS': '@im=ibus', 'GDMSESSION': 'ubuntu', 'XDG_SEAT_PATH': '/org/freedesktop/DisplayManager/Seat0', 'QT_ACCESSIBILITY': '1', 'UPSTART_SESSION': 'unix:abstract=/com/ubuntu/upstart-session/1000/1128', 'DISPLAY': ':0', 'SSH_AUTH_SOCK': '/run/user/1000/keyring/ssh', 'PATH': '/home/unknown/oe-core/layers/openembedded-core/scripts:/home/unknown/oe-core/layers/openembedded-core/bitbake/bin:/home/unknown/bin:/home/unknown/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin', 'SHLVL': '1', 'UPSTART_JOB': 'unity-settings-daemon', 'OLDPWD': '/home/unknown/oe-core/layers/openembedded-core', 'BUILDDIR': '/home/unknown/oe-core/build', 'XDG_CONFIG_DIRS': '/etc/xdg/xdg-ubuntu:/usr/share/upstart/xdg:/etc/xdg', 'XDG_DATA_DIRS': '/usr/share/ubuntu:/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop', 'DBUS_SESSION_BUS_ADDRESS': 'unix:abstract=/tmp/dbus-RP1xsh1URh', 'CLUTTER_IM_MODULE': 'xim', 'GNOME_DESKTOP_SESSION_ID': 'this-is-deprecated', 'LANGUAGE': 'en_IN:en', '_': '/home/unknown/oe-core/layers/openembedded-core/bitbake/bin/bitbake-layers', 'IM_CONFIG_PHASE': '1', 'LC_ALL': 'en_US.UTF-8', 'WINDOWID': '56623114', 'GTK_MODULES': 'gail:atk-bridge:unity-gtk-module', 'GNOME_KEYRING_CONTROL': '', 'XDG_CURRENT_DESKTOP': 'Unity', 'SESSIONTYPE': 'gnome-session', 'HOME': '/home/unknown', 'BBPATH': '/home/unknown/oe-core/build', 'XDG_SESSION_ID': 'c1', 'DESKTOP_SESSION': 'ubuntu'}, ['/home/unknown/oe-core/layers/openembedded-core/bitbake/bin/bitbake-layers']]
Running command ['parseConfiguration']
Running command ['dataStoreConnectorCmd', 0, 'getVar', ('BBMULTICONFIG',), {}]
Running command ['dataStoreConnectorCmd', 0, 'getVar', ('BBPATH',), {}]
Running command ['dataStoreConnectorCmd', 0, 'getVar', ('BBLAYERS',), {}]
Running command ['dataStoreConnectorVarHistCmd', 0, 'get_variable_items_files', ('BBFILE_COLLECTIONS',), {}]
Running command ['clientComplete']
Processing Client
Disconnecting Client
No timeout, exiting.
Exiting
--- Starting bitbake server pid 5034 at 2021-12-16 19:57:03.171736 ---
Started bitbake server pid 5034
Processing Client
Connecting Client
Running command ['setFeatures', [2]]
Running command ['updateConfig', {'build_verbose_shell': False, 'abort': False, 'dry_run': False, 'force': False, 'profile': False, 'dump_signatures': [], 'server_timeout': None, 'build_verbose_stdout': False, 'invalidate_stamp': None, 'postfile': [], 'extra_assume_provided': [], 'debug': 0, 'debug_domains': [], 'prefile': []}, {'DEFAULTS_PATH': '/usr/share/gconf/ubuntu.default.path', 'XDG_GREETER_DATA_DIR': '/var/lib/lightdm-data/unknown', 'GNOME_KEYRING_PID': '', 'GDM_LANG': 'en_US', 'XAUTHORITY': '/home/unknown/.Xauthority', 'XDG_CURRENT_DESKTOP': 'Unity', 'XDG_CONFIG_DIRS': '/etc/xdg/xdg-ubuntu:/usr/share/upstart/xdg:/etc/xdg', 'PWD': '/home/unknown/oe-core/build', 'BB_ENV_EXTRAWHITE': 'ALL_PROXY BBPATH_EXTRA BB_LOGCONFIG BB_NO_NETWORK BB_NUMBER_THREADS BB_SETSCENE_ENFORCE BB_SRCREV_POLICY DISTRO FTPS_PROXY FTP_PROXY GIT_PROXY_COMMAND HTTPS_PROXY HTTP_PROXY MACHINE NO_PROXY PARALLEL_MAKE SCREENDIR SDKMACHINE SOCKS5_PASSWD SOCKS5_USER SSH_AGENT_PID SSH_AUTH_SOCK STAMPS_DIR TCLIBC TCMODE all_proxy ftp_proxy ftps_proxy http_proxy https_proxy no_proxy ', 'OLDPWD': '/home/unknown/oe-core/layers/openembedded-core', 'PATH': '/home/unknown/oe-core/layers/openembedded-core/scripts:/home/unknown/oe-core/layers/openembedded-core/bitbake/bin:/home/unknown/bin:/home/unknown/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin', 'GTK2_MODULES': 'overlay-scrollbar', 'VTE_VERSION': '4205', 'BUILDDIR': '/home/unknown/oe-core/build', 'DBUS_SESSION_BUS_ADDRESS': 'unix:abstract=/tmp/dbus-RP1xsh1URh', 'GNOME_DESKTOP_SESSION_ID': 'this-is-deprecated', 'XDG_SESSION_PATH': '/org/freedesktop/DisplayManager/Session0', 'UPSTART_INSTANCE': '', 'SSH_AUTH_SOCK': '/run/user/1000/keyring/ssh', 'XMODIFIERS': '@im=ibus', 'XDG_SESSION_TYPE': 'x11', 'BBPATH': '/home/unknown/oe-core/build', 'HOME': '/home/unknown', 'UPSTART_JOB': 'unity-settings-daemon', 'WINDOWID': '56623114', 'CLUTTER_IM_MODULE': 'xim', 'JOB': 'gnome-session', 'QT_QPA_PLATFORMTHEME': 'appmenu-qt5', 'DESKTOP_SESSION': 'ubuntu', 'IM_CONFIG_PHASE': '1', 'DISPLAY': ':0', 'XDG_VTNR': '7', 'XDG_DATA_DIRS': '/usr/share/ubuntu:/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop', '_': '/home/unknown/oe-core/layers/openembedded-core/bitbake/bin/bitbake', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SEAT_PATH': '/org/freedesktop/DisplayManager/Seat0', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'UPSTART_SESSION': 'unix:abstract=/com/ubuntu/upstart-session/1000/1128', 'USER': 'unknown', 'LC_ALL': 'en_US.UTF-8', 'MANDATORY_PATH': '/usr/share/gconf/ubuntu.mandatory.path', 'QT4_IM_MODULE': 'xim', 'XDG_SESSION_DESKTOP': 'ubuntu', 'XDG_RUNTIME_DIR': '/run/user/1000', 'COMPIZ_CONFIG_PROFILE': 'ubuntu', 'LOGNAME': 'unknown', 'LANGUAGE': 'en_IN:en', 'XDG_SESSION_ID': 'c1', 'QT_IM_MODULE': 'xim', 'SESSIONTYPE': 'gnome-session', 'SHELL': '/bin/bash', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'UPSTART_EVENTS': 'started starting', 'LANG': 'en_IN', 'QT_ACCESSIBILITY': '1', 'XDG_SEAT': 'seat0', 'SHLVL': '1', 'GNOME_KEYRING_CONTROL': '', 'GTK_IM_MODULE': 'ibus', 'INSTANCE': 'Unity', 'TERM': 'xterm-256color', 'GTK_MODULES': 'gail:atk-bridge:unity-gtk-module', 'QT_LINUX_ACCESSIBILITY_ALWAYS_ON': '1', 'GPG_AGENT_INFO': '/home/unknown/.gnupg/S.gpg-agent:0:1', 'GDMSESSION': 'ubuntu'}, ['/home/unknown/oe-core/layers/openembedded-core/bitbake/bin/bitbake', '-k', 'tdx-reference-multimedia-image']]
Running command ['getVariable', 'BBINCLUDELOGS']
Running command ['getVariable', 'BBINCLUDELOGS_LINES']
Running command ['getSetVariable', 'BB_CONSOLELOG']
Running command ['getSetVariable', 'BB_LOGCONFIG']
Running command ['getUIHandlerNum']
Running command ['setEventMask', 1, 20, {'BitBake.RunQueue.HashEquiv': 19, 'BitBake.SigGen.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']]
Running command ['getVariable', 'BB_DEFAULT_TASK']
Running command ['setConfig', 'cmd', 'build']
Running command ['buildTargets', ['tdx-reference-multimedia-image'], 'build']
--2021-12-16 20:05:16-- https://artifacts.toradex.com/artifactory/tdxref-torizoncore-sources-frankfurt/5/x86_64-nativesdk-libc.tar.xz
Resolving artifacts.toradex.com (artifacts.toradex.com)... 3.125.132.142
Connecting to artifacts.toradex.com (artifacts.toradex.com)|3.125.132.142|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2021-12-16 20:05:18 ERROR 404: Not Found.
--2021-12-16 20:05:18-- https://artifacts.toradex.com/artifactory/tdxref-torizoncore-sources-frankfurt/5/uninative/126f4f7f6f21084ee140dac3eb4c536b963837826b7c38599db0b512c3377ba2/x86_64-nativesdk-libc.tar.xz
2021-12-16 20:05:19 ERROR 404: Not Found.
--2021-12-16 20:05:19-- http://downloads.yoctoproject.org/releases/uninative/3.4/x86_64-nativesdk-libc.tar.xz
Resolving downloads.yoctoproject.org (downloads.yoctoproject.org)... 198.145.29.63
Connecting to downloads.yoctoproject.org (downloads.yoctoproject.org)|198.145.29.63|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5874172 (5.6M) [application/octet-stream]
Saving to: ‘/home/unknown/oe-core/build/../downloads/uninative/126f4f7f6f21084ee140dac3eb4c536b963837826b7c38599db0b512c3377ba2/x86_64-nativesdk-libc.tar.xz’
2021-12-16 20:05:23 (1.76 MB/s) - ‘/home/unknown/oe-core/build/../downloads/uninative/126f4f7f6f21084ee140dac3eb4c536b963837826b7c38599db0b512c3377ba2/x86_64-nativesdk-libc.tar.xz’ saved [5874172/5874172]
and in build/tmp/log/cooker/colibri-imx6ull/console-latest.log
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-16.04"
TARGET_SYS = "arm-tdx-linux-gnueabi"
MACHINE = "colibri-imx6ull"
DISTRO = "tdx-xwayland"
DISTRO_VERSION = "5.5.0-devel-20211216162747+build.0"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-toradex-nxp = "HEAD:fa2215c138be815e678c9fe320229401c9e3e0c2"
meta-freescale = "HEAD:6d2922bee372157454e422df518b6cf0bfcf6700"
meta-freescale-3rdparty = "HEAD:c52f64973cd4043a5e8be1c7e29bb9690eb4c3e5"
meta-toradex-tegra = "HEAD:a33369073cddf81a633d2a2d9694bf1182cc4072"
meta-toradex-bsp-common = "HEAD:fddb6e505929b44dc7c98e9bb061648562e30de0"
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python = "HEAD:7889158dcd187546fc5e99fd81d0779cad3e8d17"
meta-freescale-distro = "HEAD:5d882cdf079b3bde0bd9869ce3ca3db411acbf3b"
meta-toradex-demos = "HEAD:eeaa1fa0f22496a84d42c2b54e4ae23b567b07f2"
meta-qt5 = "HEAD:b4d24d70aca75791902df5cd59a4f4a54aa4a125"
meta-toradex-distro = "HEAD:3f6705ce88f7a8dd1f026334743d6b6bf8747965"
meta-poky = "HEAD:8a9d89df2c50128130a40119a4827ace761c236c"
meta = "HEAD:44b1970c40e9d73f6e63fb10cdc55837a26f5921"
NOTE: Fetching uninative binary shim http://downloads.yoctoproject.org/releases/uninative/3.4/x86_64-nativesdk-libc.tar.xz;sha256sum=126f4f7f6f21084ee140dac3eb4c536b963837826b7c38599db0b512c3377ba2 (will check PREMIRRORS first)
NOTE: No reply from server in 30s
