Time&Date reset when power off the system
Hi
according to following article
https://developer.toradex.com/knowledge-base/how-to-use-the-real-time-clock-in-linux
sudo su
date -s "2020-01-25 15:11:40"
hwclock -w
i try to update date&time of my system , but when power off the system, its time was set to hardware
time again on next boot !!! what can i do to keep date&time update in every boot?
I assume you did insert a proper battery, right? What do the kernel messages say e.g. the output of dmesg | grep rtc?
Hi
excuse me for my delay to answer
yes i used a battery according to ixora manual(CR 1220 +3volt)
ubuntu@tegra-ubuntu:~$ sudo su
[sudo] password for ubuntu:
root@tegra-ubuntu:/home/ubuntu# dmesg | grep rtc
[    3.766176] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[    3.766183] as3722-rtc as3722-rtc.1: RTC interrupt 449
[    3.907807] rtc-ds1307 0-0068: oscillator failed, set time!
[    3.907998] rtc-ds1307 0-0068: rtc core: registered m41t0 as rtc1
[    3.908478] tegra_rtc tegra_rtc: rtc core: registered tegra_rtc as rtc2
[    3.908507] tegra_rtc tegra_rtc: Tegra internal Real Time Clock
[    6.710813] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 00:00:10 UTC (946684810)
You may want to make sure to use rtc1 which is probably the only one to preserve time & date when powering off the system.
excuse me how can i use rtc1 as only one to preserve time & date?
hi, you need to create a udev rule file as explained here.
hi
excuse me for my bad linux knowledge
i created a file 99-rtc1.rules in /etc/udev/rules.d with this content
KERNEL=="rtc1", SUBSYSTEM=="rtc", DRIVER=="", ATTR{name}=="m41t0", SYMLINK="rtc", MODE="0666"
but when i shut down tk1 the time&date reset again!!!
would you please explain me step by step what should i do
Thank you
Hi @toradexvision
I tested this and it works for me.
If you create the udev rules file, then rtc should be linked to rtc1 : ls -la /dev/rtc.
Regarding setting the time to RTC, you need to do the following:
  1. Turn off Ntp: sudo timedatectl set-ntp false
  2. Enable RTC local: sudo timedatectl set-local-rtc true
  3. Set time: sudo timedatectl set-time “2019-01-31 11:13:54”
  4. write time to RTC: sudo hwclock -w
After doing this, time should be retained even if you reboot the module.
Hi Jaski
root@tegra-ubuntu:/home/ubuntu# cat /etc/udev/rules.d/99-rtc1.rules
root@tegra-ubuntu:/home/ubuntu# ls -la /dev/rtc
lrwxrwxrwx 1 root root 4 Jan  1 00:00 /dev/rtc -> rtc0
root@tegra-ubuntu:/home/ubuntu# rm /dev/rtc
root@tegra-ubuntu:/home/ubuntu# ln -s /dev/rtc1 /dev/rtc
lrwxrwxrwx 1 root root 9 Jan  1 00:04 /dev/rtc -> /dev/rtc1
root@tegra-ubuntu:/home/ubuntu# timedatectl set-ntp false
root@tegra-ubuntu:/home/ubuntu# timedatectl set-local-rtc true
root@tegra-ubuntu:/home/ubuntu# timedatectl set-time "2020-01-29 11:12:20"
root@tegra-ubuntu:/home/ubuntu# hwclock -w
but when power off (not reboot) ixora , time&date reset again!!!
also i realized that symbolic link reset again !!!
Hi, You have typos in your udev rules file. Correct them and it should work.
hi
excuse me you was right i correct it ,but still not work !!!
What is not working? Could you share some error or output log?
hi Jaski
it seems rtc1 rules worked
    lrwxrwxrwx 1 root root 4 Jan  1 00:00 /dev/rtc -> rtc1
and output of hwclock -r is correct
root@tegra-ubuntu:/home/ubuntu# hwclock -r
Wed 29 Jan 2020 11:17:59 AM UTC  -0.429637 seconds
but i still have problem !!!
root@tegra-ubuntu:/home/ubuntu# date
Sat Jan  1 00:03:21 UTC 2000
it seems system time still not correct . perhaps i should run hwclock -s at the beginning as an autostart program , is it true?
excuse me for lot of my stupid questions perhaps it is better to block my ID in toradex community
Perfect that it works.
Yes, you are absolutely right.
No, that’s ok ;).
