Hello William,
Thank you for your detailed explanation and the information from your setup!
About the Sensor Cropping
Based on the details you provided, it appears the default mode defined in your IMX676 driver does not use the full sensor area—specifically, it’s using 3552 x 3092 rather than 3552 x 3552 pixels. This cropping (notably, a reduction in height) is likely intentional for reasons such as providing a format that matches a particular output resolution, accounting for sensor-specific requirements, or ensuring driver stability with the tested range.
Within the driver, these values define the “active” area reported to the system. Adjusting them affects how much of the raw sensor is presented to your video pipeline.
Is It Safe to Change These Values?
You’re correct not to change these values lightly, as they may have been chosen to match:
- Output image format requirements (e.g., for working with standard video resolutions).
- Sensor limitations (certain rows/columns may not be valid for readout).
- Constraints based on interface bandwidth, performance, or electrical characteristics.
- Requirements for correct MIPI CSI-2 framing or camera controller compatibility.
The areas named top, left, width, height, etc., in the driver specify what subset of the sensor is used. If the hardware and the driver support full-resolution (3552x3552) output, you could try adjusting these values as an experiment, but:
- Changing only the width/height may not be sufficient. You’ll also need to ensure the sensor registers and any MIPI configuration align with the new image size.
- Driver, sensor firmware, and ISP (Image Signal Processor) constraints could prevent using the entire sensor area. Some “edge” pixels are not used due to quality or sensor design.
- Other components (such as GStreamer pipelines or V4L2) may expect typical aspect ratios. Native square might not be broadly supported.
Next Steps (Driver Customization Context)
Since Toradex’s Torizon documentation recommends using device tree overlays for configuration but does not cover deep driver changes, and since you are not experienced in Linux driver development, you should carefully consider the following options:
1. Device Tree Overlays
Overlays are a safe way to enable hardware features or change basic configuration (such as I2C addresses or GPIOs). However, they cannot change sensor cropping or output resolution at the driver level. Device tree customization overview.
2. Driver Modification
If you wish to attempt using the full height:
- Carefully edit the mode definition in your
imx676_mipi.cto setbounds_heightandheightto 3552. - Check if register settings in
imx676_regs.hor similar source files for frame/ROI (region of interest) match these dimensions. - Rebuild and deploy the updated kernel module or device tree. Monitor kernel logs for errors.
3. Testing
After rebuilding, check video output for errors such as:
- No image (sensor initialization failure)
- Artifacts at the image edge (invalid pixel data)
- MIPI/CSI errors in
dmesgor kernel logs
Summary
- The cropping is likely intentional and may be fundamental to stable operation.
- If you modify mode dimensions, do so cautiously, and be prepared for possible video subsystem problems.
- Broad compatibility with image pipelines often favors standard aspect ratios and resolutions.
If you need further details about device tree overlays (which are safer to experiment with), you can refer to the official Toradex guide:
If you would like more specific tips for building and deploying a modified driver, please let me know!
