The Qt cross compilation with the Aplais Evaluation Board is unsuccessful
Hello Sir/Madam,
I want to build the HMI using Qt for Apalis Evaluation Test Board V1.1A , SoM: Apalis iMX6 Quad 2GB. I am following the link as mentioned below:
  1. Getting Started with Qt
  2. Qt Creator to cross compile - Embedded Linux
The image was created successfully with
bitbake -k console-tdx-image
The SDK is also successfully created with
bitbake console-tdx-image -c populate_sdk
But followed the steps to “Add the Target Device”
In Qt Creator under Build & Run - Kits upon configuring as mentioned , contains an exclamatory mark in Red "
Error: The compiler GCC+±LXDE (arm-linux-generic-elf-32bit) cannot produce a code for the Qt Version "Qt 5.5.1(qt5)-LXDE(arm-linux-generic-elf-64bit
Request your assistance, good day ahead
Amar V
Hi @amar
Could you provide the version of the software of your module?
The SDK is also successfully created with bitbake console-tdx-image -c populate_sdk
Which OpenEmbedded branch did you use to do the compilation?
Why are building an console image for QT application?
Hi @jaski.tx ,
Thank you for the feedback.
The software version for your perusal: uname -a
Linux BLTSP01121B 4.15.0-58-generic #64~16.04.1-Ubuntu SMP Wed Aug 7 14:10:35 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
The OpenEmbedded branch used is : https://git.toradex.com/cgit/toradex-bsp-platform.git/refs/tags/Apalis-iMX6_LXDE-Image_2.8b6.184-20190401
I tried building bitbake -k qt5-x11-image as well as bitbake -k meta-toolchain-qt5. But with both the Ubuntu gets hanged and need to restart and was not successful
Request your assistance for the same
Thanks and Regards,
Amar V
I tried building bitbake -k qt5-x11-image as well as bitbake -k meta-toolchain-qt5. But with both the Ubuntu gets hanged and need to restart and was not successful.
Do you have an error log for this?
Could you give the details about the hardware and software of your build host?
Hi @jaski.tx ,
The host computer hardware and software details for your perusal
Hardware:
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 94
Model name: Intel(R) Core™ i5-6500 CPU @ 3.20GHz
Software:
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
Command used: [build] $ bitbake -k qt5-x11-image
The error log is also attachedlink text
The error log specific just after this PC hangs link text
Request your help, thank you . The Ubuntu gets hanged all the time and no progress possible, need to restart
Thanks and Regards,
Amar V
Regarding your error: the error log says the following:
configure: error: Cannot find giblib: Is giblib-config in the path?
Have you done a build which was successful?
ERROR: scrot-0.8-r0 do_configure: configure failed
Could you try the solutions presented here?
Thanks and best regards,
