Thank you in advance for your help thanks to this community.
I have an apalis imx6 development board and I am configuring the host machine (Linux Mint with kernel 4.13.0) to develop a Qt application to deploy to the target device. I read and followed the instructions at the following web pages:
but when I type the command “echo $OE_QMAKE_CXX” (after source the libraries) I obtain an empty string. Do you have any suggestion?
I am compiling Qt4.8. My host machine has Linux Mint with kernel 4.13.0. I setup the SDK as described in the guides at the following links (on the Toradex web site):
First of all sorry for the delay, I tried right now and your “echo $CXX” command works (it is not empty) but I built target image for Qt4.8 (and not Qt5), with the command “bitbake -k qt4e-demo-image”. I don’t understand why it works, since in the documentation it is written that the correct command is “echo $OE_QMAKE_CXX”.
Then I installed the SDK, but when I try to run qmake, I cannot find qmake2 in the folder /usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/. And so I cannot add the correct kit in Qt Versions in Build & Run Option.
Which Documentation. The developer article of setting up qt creator is old, there will be update of this article soon.
qmake2 does not exist any more in the newer versions of Qt, so there will be an update of the article, however the build and run of application should work with the created SDK should. We tested this successfully.
Ok I understand. I didn’t know that there will be an update about it, I thought that it was the correct procedure.
Qt runs successfully, but I don’t know how to set up the correct kit because in the tutorial qmake2 was mentioned, but it doesn’t exist anymore. Do you know how can I set it up correctly?
Hello
You can look for qmake instead of qmake2 and try this. I am building the image and the SDK with Qt4. Once this is done, I can give you more information.
hello
I build the the image bitbake -k angstrom-qt-x11-image -c populate_sdk and the SDK. Afterwards, I deployed the SDK. Qmake is located in folder ./sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/bin/ of the SDK.
I tried another time, deleting the oe-core folder and following the procedure. I get all these errors, I attached the log and the conf files. Thank you very much for your time and support, I really appreciate.
No Problem.
It seems, you are not able to connect to some Internet addresses. Please check your Internet or firewall settings and change them to get access to these Internet addresses.
Sorry for my delays! It was a really busy period and I didn’t have time to investigate this problem.
I check the internet connection and it seems that the problem was during the downloading. However now I had another problem, I attached the log file. It is related to a package named libgl-mesa-dev: package libgl-imx-dev-1:6.2.2.p0-aarch32-r0.armv7at2hf-neon-mx6qdl requires libgl-mesa-dev, but none of the providers can be installed. Do you have any advise?
Thank you very much for your time and help!! I really appreciate!! link text
Please have a look here, the root cause and fix is the same.
Alternatively cherry-pick this commit into meta-toradex-nxp which basically does the same.
Thank you for your help!
I commented the line and I noticed that relaunching the shell script the log file in build/tmp-glibc/log/cooker/$MACHINE/ folder didn’t change. Is it right?
The procedure however didn’t pop-up any error, but when I try to select the qmake file in Qt a pop-up window appears and an error occurs: the format file is not correct. I followed the procedure on the website, but I still have the variable OE_QMAKE_CXX empty.
