TFTP for M4
Dear Community,
  1. Kindly provided process to send .elf to M4 processor through TFTP.
    fatload mmc 0:1 ${loadaddr} hello_world.elf
    command is not properly working through SD Card.
SD CARD is working properly.
  1. Also there are lot of errors arising from the tutorial mentioned in link below:
Kindly find the attached log file while working on M4 in eclipse IDE.
HIi @narayanamohan
Could you provide the version of the software of you module?
You need to setup a TFTP server and use the command tftp ${loadaddr} hello_world.elf && bootaux ${loadaddr}.
Please consult also the following page.
Why this command is not working properly? Do you have any error log?
What did you exactly do? Could you explain a bit more your issue?
Thanks and best regards, Jaski
