T30 - Dynamic CPU power Off
I tried to follow this link:
But didn’t have registry for dynamic CPU so I added it as seen in the picture:
alt text
I just wanted to confirm if I made it correctly. Is there a way to check if it works or I made it correctly?
Thanks.
Dear @alec
You did it all correct. To verify the effect, you can run the Toradex Task Manager V1.9 or higher. In the Performance tab, it shows which cores are turned off.
Side Note: We will release the WinCe image V2.2b2 in the next days. This version will include more dynamic power saving features (e.g. dynamic RAM clock frequency) which leads to largely reduced power consumption in low-load conditions.
Regards, Andy
