Hi.
I am using the camerademo and analog video in, ADV7180 sensor.
I wonder if there is a way to get the captured video image to fill the host window ?
Now it always keeps the apect ratio from the sensor.
Krille
Hi.
Krille
Dear @krille,
Analog camera module source code published here : https://developer.toradex.com/software/windows-embedded-compact/toradex-ce-libraries-and-code-samples#Sample_codes.
Could you please implement Direcrshow full screen API on that code, you would get help here
Also, you can check our IMX6 directshow code here.
Please let us know if you are not able to find it easily.
Thank you.
