To summarize, the option of customizing a TorizonCore does not seem feasible since the drivers have to be installed in /usr and only /etc changes can be captured with torizoncore-builder isolate . A new TorizonCore must be build with Yocto according to what was discussed in this thread : Install deb packages on Torizon target (NOT on container).
So I continue with the first option, i.e. installing and loading in the application container :
- installing the driver in the container
#%application.buildfiles%#=COPY ueye_4.94.0.1220_arm64.run /home/torizon/#%application.buildcommands%#=RUN yes y | sh /home/torizon/ueye_4.94.0.1220_arm64.run)
- running the container with the correct volumes bind mounts (
/dev,/run,/tmp,/var/run) anddevice_cgroup_rules: '["c 4:0 rmw", "c 4:7rmw", "c 13:* rmw", "c 189:* rmw", "c 81:* rmw", "c 245:* rmw"]for hotpluging usb devices.
Then I have to load the drivers manually as follows (## means the container):
# docker exec -it -u 0 --privileged <dontainerID> /bin/bash
## /lib/systemd/systemd-udevd -d
## sleep 3
## /etc/init.d/ueyeusbdrc start
nb: this is a bit weird that systemd-udevd has to be launched in the container while it is already running on the target but if it is not executed, the camera does not get recognized. Can you explain this mechanism ?
In release configuration, this can be automatized using %#application.targetcommands%# = CMD /home/torizon/entrypoint-torizon.sh
#! /bin/sh
# This is /home/torizon/entrypoint-torizon.sh
sleep 3
However, in debug configuration, %#application.targetcommands%# is not used in the moses platform template (the last CMD concerns the gdbserver) so I don’t manage to automatize the process.
So my question is : is there a way to execute entrypoint-torizon.sh in debug configuration? I was thinking of editing the moses platform template, but changing the template does not have any effect on the generation of the Dockerfiles (maybe just when the project gets created).
Can you suggest a way ?
